<<  1    2  >>
Author: Subject: Can anyone spot the mistake?
cadebytiger
posted on 29/5/07 at 03:44 PM Reply With Quote
Can anyone spot the mistake other than the linkage and the fuel lines not being on!
stevec
posted on 29/5/07 at 03:47 PM Reply With Quote
Tube on inside of trumpet back to front.
number 3cyl.
[Edited on 29/5/07 by stevec]
nib1980
fuel connector pointing differet ways, and neither of them is a T piece?
TGR-ECOSSE
posted on 29/5/07 at 03:58 PM Reply With Quote
Emmm You have posted a picture of your carbs and it should have been a picture of you dash?
snapper
1. you wont get an airfilter over them.
2. First time you rev it No.1 and 2. trumpet will break off.
I think you may need an upswept manifold
I eat to survive
I drink to forget
Hammerhead
it's a car engine
cadebytiger
posted on 29/5/07 at 04:00 PM Reply With Quote
number 3cyl.
almost... infact number 3 is the only correct one!
cadebytiger
posted on 29/5/07 at 04:01 PM Reply With Quote
been just fine for 7/8 years so far
cadebytiger
posted on 29/5/07 at 04:03 PM Reply With Quote
Originally posted by CaLviNx
yup i have to agree the big mistake is thats its a boat anchor
yes yes i know pinto junk but the V8 would not fit
flak monkey
posted on 29/5/07 at 04:04 PM Reply With Quote
Yer tit
Sera
http://www.motosera.com
cadebytiger
posted on 29/5/07 at 04:08 PM Reply With Quote
haha i know! After all that! Runs sweet as a nut now though. Sure there is more pull now the venturis are the same size!
Was moving house as the weekend and had to run the car over in the rain (only about half a mile or something). It was drifting all over the place!! Great
stevec
posted on 29/5/07 at 04:10 PM Reply With Quote
number 3cyl.
Sorry one end of a pinto looks much the same as the other to me.
jollygreengiant
posted on 29/5/07 at 04:16 PM Reply With Quote
number 3cyl.
Close I would have said no 3 is the RIGHT way round, the others need checking.
edit part. -----
HE he he. When I posted this I hadn't scrolled down any further than the first & second posts, and only found out I was right after I had posted and then scrolled down further.
I bet you've got a great big grin on your face now it runs proper like.
[Edited on 29/5/07 by jollygreengiant]
NS Dev
posted on 29/5/07 at 04:17 PM Reply With Quote
I would have said the same Rupert! Are you SURE??
The tapered thin end should be at the outer, inlet, end.
cadebytiger
posted on 29/5/07 at 04:19 PM Reply With Quote
thats what i said... number 3 is good!
flak monkey
posted on 29/5/07 at 04:23 PM Reply With Quote
The venturis have a bit pushed in the end which determines their size, its the smaller end which points to the outside of the carbs.
Sera
snapper
posted on 29/5/07 at 04:30 PM Reply With Quote
Another way to tell ( and i am looking at a Weber manual) is the fuel feed sticking down in the auxilary venturi is cut at an angle that is deeper in the auxilary venturi at the outer end slopping up towards the engine end.
I eat to survive
I drink to forget
NS Dev
posted on 29/5/07 at 04:38 PM Reply With Quote
3 still looks the wrong way round to me but it might be an optical illusion in the photo!
cadebytiger
posted on 29/5/07 at 04:41 PM Reply With Quote
Three is correct then.
Also a good clue is that it did not run and now it does with all facing as three is in photo
posted on 29/5/07 at 05:01 PM Reply With Quote
Which way round?
flak monkey
posted on 29/5/07 at 05:03 PM Reply With Quote
#3 is the correct one, all the others are wrong.
Sera
caber
posted on 29/5/07 at 05:24 PM Reply With Quote
I can confirm that the Pinto makes a better car engine than a boat anchor, I did a little experiment in my dinghy at the weekend, didn't even make it to the water the trailer snapped in half
Caber
Macbeast
posted on 29/5/07 at 06:08 PM Reply With Quote
The biggest mistake is you forgot to reduce the picture to a reasonable size
goodall
posted on 29/5/07 at 07:16 PM Reply With Quote
boot anchors arnt even heavy, the one on our boat is made from a light alloy
cadebytiger
posted on 30/5/07 at 09:08 AM Reply With Quote
i did reduce it. it was alot larger than this and it all fits on my screen lol
<<  1    2  >>
