Author: Subject: new engine req for a book built xflow 7
steve m
posted on 16/3/08 at 07:44 PM Reply With Quote
I have been thinking about changing my outdated 1700 xflow in my locost , to something more modern, and unleaded
I do NOT want to go BEC, so must be a usable powerfull 1600 ish engine, with the possibilty of adding more power
problems,
crankshaft pully to top of engine (height) could be an issue, as even the xflow is a tight fit under the bonnet,
Exhaust prefered on the LHS
a normal type of engine, ie rover k
any idea's ?? prefrably with measurements !!
regards
steve
nib1980
posted on 16/3/08 at 07:50 PM Reply With Quote
zetec?
Vauxhall?
What you doing with you old engine?
steve m
posted on 16/3/08 at 07:56 PM Reply With Quote
Zetec is to tall, at the front, assuming ive meausured correctly !!
Vauxhall ugh !!
the old xflows (3 in various states of build) will all go on fleebay, but not for a while as this may take a year to put the plan together
My car
<<<----- is Very low, to the ground, like me !! and also in usable engine height available
one option would be to sit the engine further back, assuming i can get a narrow gearbox, at present a ford type 9
[Edited on 16/3/08 by steve m]
rayward
posted on 16/3/08 at 07:57 PM Reply With Quote
my choice would be Zetec SE Engine (as used by shawspeed)
good for 150 BHP with modded intake and exhaust
shawspeed sell the bellhousing to fit to a type 9
hth
Ray
paulf
posted on 16/3/08 at 08:15 PM Reply With Quote
I have a Zetec in a book built car with a Caterham nosecone.It is a tight fit , I cut the sump down level with the bellhousing and found that the timing belt cover was about 20mm higher than the nose cone and came about 25 mm in front of the bonnet lip with about 3.5 inches of ground clearance.
I debated ways of making it fit and nearly decided against fitting it, but eventually cut the nosecone to give clearance.
It was well worth doing and although I intend to make a scoop to fit over the cam cover i havent yet but the extra power was well worth the effort.
You could move the gearbox back to get the engine behind the nose cone and it would then be easy to sort the bonnet.
Paul.
D Beddows
posted on 16/3/08 at 08:32 PM Reply With Quote
2nd vote for the Zetec SE. They're actually lighter and smaller than a crossflow plus, as has already been said, getting 150bhp out of them isn't that expensive - and much much much cheaper than getting anything like that from a crossflow
[Edited on 16/3/08 by D Beddows]
UncleFista
posted on 16/3/08 at 08:50 PM Reply With Quote
If it's a book chassis, with standard nose etc. a Zetec fits with no chassis/body mods, bit of a squish, but definitely fits
[Edited on 16/3/08 by UncleFista]
Tony Bond / UncleFista
posted on 16/3/08 at 09:27 PM Reply With Quote
Zetec SE loverly little alloy engine..
However for me a 2.0 zetec with a T35 turbo.. brrrrrrm. 400bhp pish woosh......
Taz Surfleet
posted on 16/3/08 at 09:37 PM Reply With Quote
pardon the ignorance but whats the differences between the SE and standard zetecs?
Schrodinger
posted on 16/3/08 at 09:45 PM Reply With Quote
LOTS
They are not remotely similar engines.
Zetec iron block inlet on drivers side exhaust on passenger side
SE alloy block inlet on passenger side exhaust on drivers side IIRC is also a joint venture with Toyota non standard gearbox fitting
Keith
Aviemore
TimC
posted on 16/3/08 at 10:40 PM Reply With Quote
Would be a 20V Toyota 4AGE for me!
posted on 17/3/08 at 09:46 AM Reply With Quote
anyone got any mneasurments from centre of crank to top of cam cover for the toyota and zetec se?
bob
posted on 17/3/08 at 10:50 AM Reply With Quote
Some zetec measurements,i'm sure someone will have some exact cambelt cover to chopped sump measurements.
This will help to go along with.
Also seadog (mark) is fitting a zetec SE into his indy, i know the dimensions of the indy chassis are bigger/taller but he should be able to give the engine measurements.
bugger the image is too big
[Edited on 17/3/08 by bob]
bob
posted on 17/3/08 at 10:53 AM Reply With Quote
steve m
posted on 17/3/08 at 06:47 PM Reply With Quote
Well!!
Thanks for all the response, looks like a zetec, once ive sorted all th measurments
regards
steve
posted on 17/3/08 at 06:54 PM Reply With Quote
Originally posted by steve m
Vauxhall ugh !!
Why ugh? The 1.6 Ecotec is a fantastic little engine, all alloy with huge valves giving big power potential. Have a look on SBD's web site and you can see dyno plots of this engine giving 164bhp from a bolt on throttle body kit (and presumabely a decent exhaust), but no internal mods.
Well worth considering this engine, I'm really surprised it isn't used more.
