Author: Subject: re-programming laserline 996 alarm remotes
NS Dev
posted on 18/4/09 at 02:02 PM Reply With Quote
anybody got a laserline 996 alarm on here and know how to reprogram remotes?
The shogun I have recently bought has one on it but only came with one "electronic key" and no remote fobs.
It works fine using that, but if i lose it i am in the poo (you can't turn it off by key and its an immobiliser too, and been properly wired in unlike most! )
I know the laserline remotes should be recodable but the instructions on laserline website don't work, (they don't list the 996 anymore) and the 996 instrucitons i have don't cover recoding!
UncleFista
posted on 18/4/09 at 02:27 PM Reply With Quote
(closest I could find in my intruction manual)
Remote Handset Synchronisation:
In particular situations (remote battery change) , on return to the vehicle it may be necessary to push and hold down arm/disarm buton of the remote until the green LED on the remote extinguishes.
This should be performed whilst standing adjacent to the vehicle. Depressing button a second time will synchronise the system and resume normal operation of the handset. Should the LED fail to extinguish, the battery needs replacing.
[Edited on 18/4/09 by UncleFista]
Tony Bond / UncleFista
UncleFista
posted on 20/4/09 at 11:09 AM Reply With Quote
Did it help at all ?
posted on 20/4/09 at 05:14 PM Reply With Quote
This is for synchronising the rolling code in the keyfob and alarm if they get out of sync. This can sometimes happen if you activate the fob out of range of the car.
You can't program a new remote into the alarm like this...if you could then anyone with the same type of alarm could program their remote into your alarm!
UncleFista
posted on 21/4/09 at 01:26 AM Reply With Quote
Ah right, should read slower
I've been trying to switch off the "auto-arm" on mine. I took it apart to set the appropriate dipswitches, to find it doesn't have any....
Bugger.
