Author: Subject: Honda blackbird engine ID / year
madrallysport
posted on 16/11/09 at 04:33 PM Reply With Quote
I bought 2 blackbird engines, one has a small fault in it, but it was cheap the other is in good condition (or so i've been told) I have bought engines only, one has thottle bodies but no injectors in it, i also require wiring harness and an ECU, but to get this i need to find out the age of the engines, i have the engine numbers -
SC35E-3101843 & SC35E-3501259,
can anyone help me identify the year from the above numbers please.
UNDERSTEER is when you hit the wall with the front of the car.
OVERSTEER is when you hit the wall with the rear of the car.
HORSEPOWER is how fast you hit the wall.
TORQUE is how far you take the wall with you.
Mike S
posted on 16/11/09 at 06:05 PM Reply With Quote
SC35E-3101843 is 1999
SC35E-3501259 is 2002
Harness and ECU from any of the injected birds should do you.
Make sure you get the matching ignition lock and key with the ECU though.
Mike
There are more horses' asses in this world than there are horses
madrallysport
posted on 17/11/09 at 08:34 AM Reply With Quote
Thanks Mike
I also need injectors / injection rail, are there any differences in them.
