R1 5pw oil connections
Beamerboy - 18/6/19 at 08:43 PM
Hi just after bit of advice on fitting oil temp and oil pressure on 2003 r1 5pw engine
I have a DD2 Lite dash and want to fit the oil temp sensor and also the oil pressure sensor any help on best place to fit these on the engine much appreciated
Thanks in advance for any help and advice and any pics showing the best way to fit them.
adithorp - 18/6/19 at 09:09 PM
On 5pw people usually drill and tap the oil cooler bolt for oil pressure sensor.
JekRankin - 18/6/19 at 10:03 PM
For oil temp, I replaced the oil level switch with an aluminium adaptor with a 1/8NPT tapping for the sensor to screw into. Works well.
[img]https://photos.app.goo.gl/5ECuxnbjRLPe5BK17[/img]
[Edited on 18/6/19 by JekRankin]
adithorp - 19/6/19 at 09:01 AM
Sorry meant to add what Jek said. Alternatively on my 5vy I drilled/tapped the sump at what I think is a fairing mounting point. It's thicker there but still less than I'd like but I wanted to retain the oil level sensor at the time.
Beamerboy - 19/6/19 at 07:33 PM
Adithorp and Jek many thanks for taking the time much appreciated I had read this but thought best to ask as so much knowledge on here , thanks again
JekRankin - 19/6/19 at 08:02 PM
No problem, if you need a drawing of the oil temp sensor adaptor I made up, let me know.
Jek
[Edited on 19/6/19 by JekRankin]
Beamerboy - 19/6/19 at 08:05 PM
Jek
If itís not too much trouble that would be fantastic thanks
JekRankin - 19/6/19 at 09:44 PM
Sure, if you u2u me your email address I'll send it over.
Jek
Beamerboy - 19/6/19 at 09:58 PM
Jek
U2u sent thanks
