rdodger
posted on 30/10/11 at 10:31 PM |
7" LSD, disc brakes and 13" wheels?
Evening all.
On my new project I will be using a sierra 7" lsd which i believe I have to use Lobro driveshafts on.
I also want to use 13" wheels and wilwood powerlite handbrake calipers. If I buy the Wilwood kit it would use a 240mm disc and a drum bearing
carrier/hub with a seperate fabricated carrier. This set up would be the push in driveshaft?
So the question is can I get a combination of parts to enable me to fit the LSD, Lobro shafts and smaller 240mm disc with wilwood caliper?
posted on 30/10/11 at 11:05 PM |
you can get custom shafts made to have different ends on them, and also i believe it is possible to end up with a pushfit LSD, though i think its a
case of putting the lsd mechanism into a pushfit diff. Not sure which ends up cheaper though!
Grimsdale
posted on 31/10/11 at 08:19 AM |
mix and match driveshafts to get lobro inner and pushfit outers. There's a chap on rhocar who has done it.
adithorp
posted on 31/10/11 at 08:24 AM |
Don't know about the 'shafts, but if it's the Wilwood drum to disc conversion that RallyDesign do, you need to get the drive flanges
deduced in diameter for te discs to fit.
You can remove the bolt on flanges from the diff by removing the circlip on the inside but don't know if the push fit shaft is the same
dimensions or whether the outer end, bolt on stub, is the same dimension as the outer push fit shaft end.
http://jpsc.org.uk/forum/
mcerd1
posted on 31/10/11 at 09:03 AM |
push-in shafts don't fit into Ford LSD's - they need unequal length stub's to work (different from the open diff's)
hybrid shafts can be made by fitting a lobro CV onto one end of the right sort of push-in shaft, but these have issues with the lobro's wearing
out quicker (aparently due to the load the push-in type CV puts on them, which would make sence to me - there are a few old treads about this)
so I think your plan of fitting the calipers onto what you've got using whatever discs will fit sounds like the best answer to me
not sure which discs would make this all work, but whatever they are you should be able to make them fit even if it means making some custom mounts
for the calipers.... (I'm planning an upgrade for my fronts - but there are no kits for what I want either)
have you got the wheels already ?
and if so whats there internal diamiter ? (some wheels have more space than others)
the other question is do you really need the willwood calipers ? the ford ones should be more than enough for the back of most cars and if its the
weight your worried about there is a cheaper option of using alloy calipers from a golf (mk4 I think, but its one specific type your after)
[Edited on 31/10/2011 by mcerd1]
rdodger
posted on 31/10/11 at 09:06 AM |
Thanks Adi/Grimsdale
I think from my research that can be done but doesn't work as the stubs are different lengths?
I wonder if the disc bearing carrier could be modified to suit? Basically make it look like the drum one then bolt on the wilwood kit?
With the drive shafts would it just be a case of removing the inner tripod and fitting the lobro joint?
[Edited on 31/10/11 by rdodger]
adithorp
posted on 31/10/11 at 09:10 AM |
But are the outer bolt-on stub axles and flanges the same dimensions as the push in shaft ends and stub axles?
If they are, Roger can use them on the rear hub and use his bolt on shafts and LSD.
mcerd1
posted on 31/10/11 at 09:12 AM |
no they are different too (different bearing size I think)
but iiyama's the man to ask about this - I think he did exactly the opposite and made the disc type hub carriers fit the push-in setup so that
he didn't need an adaptor kit to fit the rear discs....
adithorp
posted on 31/10/11 at 09:16 AM |
opps, to slow...
To use a hybrid push-in one end, lobro the other end the problem in the push in is spring loaded and pushes against the lobro. The same occures with
my hybrid Freelander-Sierra shafts. I modified my Sierra ends to make them self centering and not press the inner end. It's a long explanation
of how I did it and already on here somewhere if you care to search.
snapper
posted on 31/10/11 at 09:30 AM |
Needs the thicker Desiel push fit drive shafts 27mm and the lobros from standard 27mm
Standard push fits are 24mm.
Remove inner tripod and replace with lobro
Some push fit diffs can be made up with lobro stubs a bit of work needed to clear the planet gear axle
If fitting discs on the rear you'd be better off with a full disc axle and just replace the diffs for an LSD
I eat to survive
I drink to forget
rdodger
posted on 31/10/11 at 09:41 AM |
Not bought the wheels yet
The reason for the messing about is to use an LSD with 13" wheels without spending 1k on a quaife diff
Looks like the easiest way to do this would be to fit the lobro driveshafts, disc brake set up and modify the bearing carrier to accept the
caliper.
I don't want to use a set up that might shorten the life of the shaft. I do have a couple of friends who have snapped driveshafts a long way
from home!
The Wilwood caliper seemed like a good idea to fit the 13" wheels and seems to work well with powerlite fronts on a sierra master cylinder.
What brake setup have you got Adi? You using a Freelander diff?
Rog
ps Adi I have lost your phone number. U2u it and I will call you and pop over for a catch up soon.
mcerd1
posted on 31/10/11 at 10:07 AM |
if you can do some measuring up and find out what room you'll have to play with inside the wheels then I'm sure you'll find a way of
making it all fit with the lobro's on both ends (even if it means a few £ to machine some hubs/discs to fit)
once you've got a few sizes I could draw it up for you and see what the issues are...
rdodger
posted on 31/10/11 at 10:14 AM |
Thanks for the offer.
I will get measuring when all the bits arrive.
adithorp
posted on 31/10/11 at 10:27 AM |
Rog
I'm running Freelander quaife diff', hybrid shafts (outer Sierra push-in / inner Freelander), Sierra drum type hubs, Wilwood powerlight
calipers all round (with RD's Seirra drum to disc conversion) and Compomotive CXR 13" rims.
u2u on it's way.
Someone is bound to be along to say how poor the handbrake is with the wilwoods. Hobbsy or Jim what they think of mine. ...and 2 of those broken
shafts were driver abuse!
jimgiblett
posted on 31/10/11 at 12:50 PM |
Only one of the driveshaft failures was due to extreme abuse the other was down to a dodgy repair. Hand brake is excellent on drums
Rog - IIRC Andy Bates prepped an RGB Striker with Standard Sierra LSD and calipers inside 13" CXRs. A bit of fettling with a grinder was
required. Also someone on the sevens list was running VAG calipers on an otherwise standard Sierra back end with 13s but never saw that one.
I do need to get an ATB in the Fury but I have blown all my spare cash and some on the ATM (Alfa Turbo Mongrel)
- Jim
mcerd1
posted on 31/10/11 at 12:52 PM |
just to be clear: I think the freelander dirveshafts are the same type (tripod) as the push-in sierra ones (someone correct me if I'm wrong) and
that should be fine, its just mixing them with the bolt-on/lobro ones that gives the problems with wear (the lobro's normally just
'float' and arn't designed to take the 'thrust' load that the spring in the tripod ones produces)
adithorp
posted on 31/10/11 at 01:30 PM |
Yes, the Freelander joints are tripod type, but unlike the Sierra ones they aren't spring loaded.
On the sierra the two ends push against each other and centralise the shaft/joints. On the Freelander niether end is sprung and the joints just find
the middle naturally (bit of spring in the boot and the air trapped inside). With just one end sprung (in the hybrid), then the Sierra outer joint
pushes fully out and the Freelander end is forced fully in. Mine knocked in use originally. I modified the Sierra end to be self-centering by reducing
the original spring length and adding another acting against it. I wasn't sure it'd work or how long it would last. It's been like
that for 13000 miles now: No knocks, no problems.
rdodger
posted on 31/10/11 at 02:29 PM |
I take it the bearing is different in the disc bearing carrier to the drum one and you can't simply swop the bearing?
I have found a couple of suppliers selling alloy bearing carriers. I guess these are for drum though.
linky
Just got off the phone with these guys. They are disc carriers without the lugs! Looks like I might have found the solution!
linky
mcerd1
posted on 31/10/11 at 02:43 PM |
^^ they should work then, but the issue could be finding a disc that fits the hub...
rdodger
posted on 31/10/11 at 03:23 PM |
The escort mk3 240mmx10mm disc fits it you turn down the flange to 134mm. Then I can fit the Wilwood powerlite caliper. Happy Days
phelpsa
posted on 31/10/11 at 06:44 PM |
I modified my disc type carriers and fitted 240mm discs. I used peugeot calipers though. Cut down the
Theres a few pictures in here:
http://s125.photobucket.com/albums/p60/LocoPolo/Locost/
rdodger
posted on 1/11/11 at 10:08 AM |
I'm getting a little confused, not a difficult thing!
Having spoken to the manufacturer of the alloy bearing carrier they confirm that the are the disc version without the ears for the caliper carrier.
All good so far.
They then went on to tell me that the drum and disc bearing carrier are the same dimensions and bearing size apart from the ears.
Can anyone confirm or deny this?
Rog
rdodger
posted on 9/11/11 at 10:50 PM |
Anyone?
Minicooper
posted on 9/11/11 at 11:14 PM |
One thing I do know is different, the drum brakes carriers have a 80mm diameter location ring and the disk braked carriers use a 82mm locating ring.
Although I believe this can vary.
hobbsy
posted on 10/11/11 at 01:38 AM |
Adi's handbrake has the best action I've felt on a kit car. Other than one rally prepared which had a hydraulic handbrake
And Jim is the driveshaft killer - I've merely been a donor on one occasion (after I broke something more expensive and terminal!)
Quaife ATB's are very nice especially around the Alps Somewhere in the future when I have some spare time I'll dig out the video of
Adi and I synchronised powersliding up various mountain pass hairpins
