<<  1    2    3  >>
New Topic New Reply
Author: Subject: AGM WLR V12 - Arrival
StuartBJ
posted on 9/8/10 at 01:15 PM Reply With Quote
Well the hoist had no problem lifting it to full height on the 250Kg setting. Hard to define the weight but must be about 200Kg.
I have a Megasquirt unit for the engine MS extra with 2x v6 coil packs (ford).
The fueling is via the original merc pump (complete with swirl pot) but I havn`t run any lines yet and I`m waiting for a follow up pallet of parts to turn up.... including the fuel tank.
I have ditched the original TB`s which were stepper motors (drive by wire) for some shiny red ali 80mm cable operated ones.
I will try and detail the install at each step with pics. I`m sure lots of people will be intrested in the Megasquirt.
posted on 9/8/10 at 01:17 PM Reply With Quote
Sounds like fun... looking forward to it!
It's Evolution Baby!
Richard Quinn
posted on 9/8/10 at 01:20 PM Reply With Quote
Originally posted by 02GF74
and how will you be fuelling it?
From a tanker!
Nice job!
StuartBJ
Wheels and Tyres
Hmm..... fair comment
But another good story....
I have a set of NEW Merc ML alloys 9.5 inches wide (Rear) for £160 (via ebay) from a specialist alloy shop in essex that couldn`t sell them
The mecredes alloys fit Granada hubs (5x112)......
What size tyres do you think are best for these rims 18" x 9.5" ....255? 245? 265? 275?
[Edited on 9/8/10 by StuartBJ]
posted on 9/8/10 at 01:31 PM Reply With Quote
Originally posted by StuartBJ
Originally posted by nick205
That's a big motor...!
Out of interest...who rates the chasis at 500bhp (any torsional or stress testing results)?
...and what mods have been made over the standard (MK Indy based) chasis?
AGM had the original chassis and wishbones stress tested on a jig and then a report was produced (which makes a good read). The conclusion and suggestions were then developed in to the chassis you see in the pictures and the new chassis was re tested.
If you look at the the AGM pics it shows a few good pictures of the chassis for you to compare but basically there is extra strengthening and cross members etc + recomended panelling and widening to increase rigidity.
That's very encouraging to hear - often these things are claimed with little in the way of real evidence.
Looking forward to your progress, should be a beast and half!
iank
posted on 9/8/10 at 01:33 PM Reply With Quote
Originally posted by scudderfish
Originally posted by hughpinder
Wow - Impressive ... Can we have a sweepstake on how long the rear tyres last?
Regards
Hugh
About 100m
miles or meters?
Anonymous
posted on 9/8/10 at 01:49 PM Reply With Quote
I've seen your fuel tank.
bimbleuk
posted on 9/8/10 at 02:04 PM Reply With Quote
Probably a little bit north of 200kg but the LSx engines are around that with the ancilliaries. However using the T5 will save a useful amount of weight compared say the T56 usually fitted to the LSx engines. I know because I've lifted one and it's big and heavy.
I also ditched the DBW (on a LS1 not a V12) and went for a cable throttle. They are good for emmisions plus economy at light throttle and can be integrated into traction control but often loose the pure response of a cable throttle.
[Edited on 9-8-10 by bimbleuk]
StuartBJ
posted on 9/8/10 at 02:10 PM Reply With Quote
Ha ha....I hope not
Here is the actual fuel tank
posted on 9/8/10 at 02:36 PM Reply With Quote
Is that for range or simply to get some traction weight over the rear wheels...?
scudderfish
posted on 9/8/10 at 02:38 PM Reply With Quote
Ha ha....I hope not
No, that's just the swirl pot, this is the fuel tank
StuartBJ
posted on 9/8/10 at 03:04 PM Reply With Quote
I suspect it was built to fit but it does have the added benefit of both as Alan used an LS1 in the demo car and that can`t be exactly.....froogle lol
franky
Soa genuine 180 mph!? Thought real men turbo those engines
on a serious note, would it not be worth running a dta type ecu?
StuartBJ
posted on 9/8/10 at 03:23 PM Reply With Quote
I don`t really know enough about them to be honest.... I counted my lucky stars when I found someone that could supply an ECU that would be wasted spark on a 12 pot. If it works I will be happy
MakeEverything
As an LM prototype car, i would surmise that it was sized for 10 laps (or so) of Le mans!
Kindest Regards,
Richard.
kb58
posted on 9/8/10 at 03:55 PM Reply With Quote
A chassis isn't "designed" for horsepower... the chassis only knows about torque, more specifically, the maximum amount transferable to the ground, probably be a lot less than what the engine can develop. So, it really comes down to what tires the designer worked off of. Hopefully he designed it for worst-case, racing slicks, and not all-season tires!
[Edited on 8/9/10 by kb58]
And its book - http://www.lulu.com/shop/kurt-bilinski/kimini-how-to-design-and-build-a-mid-engine-sports-car-from-scratch/paperback/product-4858803.html
Dangle_kt
posted on 9/8/10 at 05:19 PM Reply With Quote
Wow.
Just wow.
MakeEverything
posted on 9/8/10 at 06:45 PM Reply With Quote
But if you said to Joe Public that the chassis was designed for 600lb/ft of torque, they wouldnt understand.
Horsepower in this case is a reference method methinks.
Kindest Regards,
Richard.
StuartBJ
posted on 11/8/10 at 11:00 AM Reply With Quote
Yes, I agree.
We all know that its actually torque that is the important factor but we all still "speak" in terms of BHP (or KW) when it really should be lb`s.
kb58
posted on 11/8/10 at 01:28 PM Reply With Quote
Originally posted by MakeEverything
...But if you said to Joe Public that the chassis was designed for 600lb/ft of torque, they wouldnt understand.
Agreed, but since we aren't Joe Public here, I'm curious what torque the designer built the chassis for. If he says "500 hp", I'd be concerned!
StuartBJ
posted on 11/8/10 at 02:36 PM Reply With Quote
You`ve hit the nail on the head... It is aimed at Joe public looking at starting a new kit aswell as the more "experienced" enthusiast... Even today I saw "a which chassis" question posted.
I agree that its not technically right..... but it gets the point across to the masses.
The Black Flash
posted on 11/8/10 at 03:31 PM Reply With Quote
I wouldn't go by what the hoist managed. I used mine to lift my lathe on the 250Kg setting, only to find out later that the lathe was actually around 900Kg
James
posted on 13/8/10 at 03:11 PM Reply With Quote
I'm a little concerned by the absence of any tubes to stop the engine bay lozenging. They are missing on the MK too but it's very hard to get this vital chassis strength back.
I know it's hard to fit them in the engine bay with a big engine so the alternative is a 'Y' brace.
This is all outlined in Cymtrics' mods and documentation which you'd do well to investigate.
James
phelpsa
posted on 13/8/10 at 10:13 PM Reply With Quote
The chassis only sees the reaction force from the tyres. Torque at the flywheel means just as little as bhp when it comes to chassis design once you factor in diff's and tyre diameters.
[Edited on 13-8-10 by phelpsa]
kb58
posted on 14/8/10 at 12:37 AM Reply With Quote
I don't agree that it's all about tires, though. The chassis does see engine-reaction torque along its length, which does indeed twist it. Yes, it'll be less than the maximum torque that the engine produces, due to the tires "bleeding off" torque above some amount.
Ironically, mid-engine cars have far less of a problem in this regard, and transverse mid-engine cars have no chassis twist at all!
[Edited on 8/14/10 by kb58]
<<  1    2    3  >>
New Topic New Reply
