<<  1    2  >>
New Topic New Reply
Author: Subject: Chassis welding
Nickp
posted on 2/8/15 at 10:37 AM Reply With Quote
Well I got the engine as far back as it'd go and low enough to clear the Equinox bodywork by a few mms. In that positionI had the sump about 75mm below the chassis!! So in my opinion it definitely needs chopping, unfortunately.
I've seen those manifolds too but I'm going to try with the std ones first in true Locost fashion.
MBrown
posted on 2/8/15 at 11:22 AM Reply With Quote
I'll watch your results then before I get a new manifold and will have another look at the sump when it's back in, and it might be best to eventually set it up with a dry sump system
[Edited on 2/8/15 by MBrown]
Nickp
posted on 3/8/15 at 04:23 PM Reply With Quote
I've just had a go at the rear manifold. Chopped the outlet and lambda sensor off. Spun it round to clear the head and get a better angle to poke it out of the side of the bonnet. I intend to poke the front one out just below this one before joining them up.
Nickp
posted on 3/8/15 at 04:43 PM Reply With Quote
Here's my finished sump-
Have you seen the price of an M52 dry sump kit?? Deffo not locost!!
MBrown
posted on 3/8/15 at 05:36 PM Reply With Quote
Oh, I might have a problem with doing that with the exhaust manifold due to my bracing in the engine bay......
[Edited on 4/8/15 by MBrown]
Nickp
posted on 3/8/15 at 05:51 PM Reply With Quote
Originally posted by MBrown
Oh, I might have a problem with doing that with the exhaust manifold due to my bracing in the engine bay...... &#128533;
Dunno yet, I'll investigate that next
MBrown
posted on 4/8/15 at 06:18 PM Reply With Quote
Today I have spent what seems like forever welding on 100 brackets! I decided I didn't want to drill the chassis repeatedly to then rivet the fuel, brake lines and electrics so I managed to find these which were 100 for £40. They also have the added benefit of keeping the chassis sealed, which hopefully should make it last longer without rusting slowly inside. This also means that when i bolt P clips to them, I can change, replace or repair any fuel lines etc without the need to drill rivets and therefore not leaving any bits of rivet rattling around in the chassis. I spaced them out every 10cm, and 100 seemed to be enough to cover every possible route for electrics, fuel lines and brake lines.
MBrown
posted on 6/8/15 at 07:44 PM Reply With Quote
Chassis finally finished! Thanks all for the advice and guidance!
Slimy38
posted on 6/8/15 at 08:20 PM Reply With Quote
Nice idea, and I understand your concern around rattling rivets!! I guess with a BMW engine you're not overly worried about minimising weight, so a few extra brackets won't make much difference.
Where did you get them from?
MBrown
posted on 6/8/15 at 08:29 PM Reply With Quote
I got them here:
ebay brackets
Definitely easier than drilling many many holes..... and as you pointed out I have a relatively heavy engine so I wasn't too worried about adding the extra weight. I also used slightly thicker metal for my chassis so it is approx 25kg heavier than the usual but it is a lot stronger.
ceebmoj
posted on 6/8/15 at 09:34 PM Reply With Quote
I did a similar thing on mine but used washers bent at 90 and tacked the corners to the chassis.
Slimy38
posted on 6/8/15 at 10:06 PM Reply With Quote
Ah, much more my style (and price range!)
MBrown
posted on 7/8/15 at 06:24 AM Reply With Quote
I tried the washers idea but the heat from welding left them too easy to break off, I could've got some heavier duty washers but then saw those brackets
Slimy38
posted on 7/8/15 at 10:33 AM Reply With Quote
Stainless washers I guess? I did a bit of digging last night, with most washers either being BZP, galvanised or stainless, I have the option of poisoning myself or working with brittle metal after welding.
Or I could just use the 2mm steel I have and make some of my own!
By the way, what's your plan with regards to fixing? Are you still using rivetted p clips in the holes or something else?
MBrown
posted on 7/8/15 at 12:29 PM Reply With Quote
I managed to find some mild steel washers relatively cheaply, that then avoids poisoning and saves the time of making something:
http://m.ebay.co.uk/itm/M5-Mild-Steel-Washers-14-5mm-O-D-X-5-4mm-I-D-X-1-4mm-Thk-/141718028183?nav=SEARCH
The above washers are quite small, the same person did have an auction with some that were 19 mm OD, so message him if you do want a bigger size, the 19mm OD didn't cost much more.
with my brackets I have bought some short bolts so will bolt lines in place- again may add a small amount of weight but makes it so easy to repair or alter later on.
Hope that helps
[Edited on 7/8/15 by MBrown]
Vipo
posted on 11/9/16 at 07:23 PM Reply With Quote
Hi there, sorry for the stupid question but your chassis a standart o 442?
MBrown
posted on 12/9/16 at 08:18 AM Reply With Quote
Hi, it is the standard Haynes Roadster chassis from the Haynes Roadster book completed by Chris Gibbs
craigdiver
posted on 13/9/16 at 09:16 PM Reply With Quote
I was hoping to take the 6 outlets through the side of the chassis then combine them into two 3 into 1 and bring two exhausts along the side of the car. Is there any good reason to take the exhaust over the engine bay upper chassis rail? (Will it interfere with the steering column?)
Craig
If it ain't broken, fix it anyway (just because).
Building - BMW powered Haynes Roadster/442E hybrid.
Volvo C30 T5 Polestar
craigdiver
posted on 13/9/16 at 09:23 PM Reply With Quote
Cooling system
Mark,
Wonder if you can help, I'm confused by the cooling ststem on these engines, appears to be two circuits, cylinder block fed from the water pump and a second circuit through the cylinder head. Do you know how this setup will be plumbed in with a radiator and expansion tank?
I found this diagram but cannot make sense of it...
post img
Craig :-)
MBrown
posted on 25/9/16 at 02:41 AM Reply With Quote
Hi Craig,
I haven't yet plumbed mine in so I don't know exactly, I did work it out from the manual several months ago but would have to have another look. From a quick google I think this is a slightly better picture. Most of the connections should remain exactly the same. The only one that you would have to change is the one on the upper right hand side of the picture. The two pipes going away from the engine on the upper right hand side go to the heater in the car and return from it, so if you don't use a heater then these two can just be connected together. I will be using a heater so my connections should be exactly the same. There are a couple of other people who have completed their builds with this engine - Steve Wallace being one and he has been incredibly helpful.
Hope this helps,
Mark
craigdiver
posted on 25/9/16 at 07:48 AM Reply With Quote
Hi Craig,
Hope this helps,
Mark
That is a massive help, my donor had three hoses going to a double solenoid assembly before going through to the heater matrix, I suspect it bypasses the flow to the matrix when not needed.
Thanks Mark
<<  1    2  >>
New Topic New Reply
