deanwilson
posted on 7/11/08 at 07:58 PM |
help runnin problems
hi there i have jus done a head gasket and when i started the car it ran really rough and then jus stalled i think its the timin which is out any
ideas any help would be much appricated
mr henderson
posted on 7/11/08 at 08:03 PM |
Need lots more info from you, for instance, what sort of engine is it?
Cam timing could well be an issue (assuming it's an OHC of some sort) as well as the ignition timing
John
deanwilson
posted on 7/11/08 at 08:13 PM |
hi there it is a renault megane 1.6 8v
mr henderson
posted on 7/11/08 at 08:21 PM |
I can't imagine you are going to get much help with this unless you give us a LOT more information.
John
posted on 7/11/08 at 09:02 PM |
Suspect the first thing to check would be the cam timing.
l0rd
posted on 7/11/08 at 09:48 PM |
when you did the timing, did you lock the crankshaft with the renault tool or not? If you didn't, you might got the wrong timing, causing the
valves to bend!!
