Richtiger
posted on 8/11/08 at 04:14 PM |
measuring my hose! haha
need to get a new hose for between expansion tank and water pump. measured the diameter of expansion tank outlet and its 0.3 inches but me being
shocking at maths my vernier caliper has inch scale split from 1-9 so startat 0 then 9 marks then 1inch. so what i measured is 3/9 in this scale. but
how do i convert that into the say 16th scale scale? god i wish id listened at school.
Rich
speedyxjs
posted on 8/11/08 at 04:30 PM |
Its easier in mm
dinosaurjuice
posted on 8/11/08 at 04:34 PM |
i think your after 5/16th's or 8mm hose.
WIll
EDIT: unfortunately schools dont teach imperial in maths or even 'relevant maths' - the only have time to teach whats in the gcse exam
papers.
im 19 and proud of the fact im fluent in metric and imperial. i use both everyday and it makes life soo much easier. i remember asking my metric
convinced maths teacher how tall he was, he replied instantly 6'1" - need i say more?
[Edited on 8/11/08 by dinosaurjuice]
Richtiger
posted on 8/11/08 at 04:38 PM |
its a touch over 7mm. is that one known as the vacum hose? comes out of the top of the header tank and goes to water pump?
dinosaurjuice
posted on 8/11/08 at 04:44 PM |
im not sure of the proper term for it, but it allows a small amount of water to circulate around block when stat is closed. helps to warm engine up
evenly. it shouldnt be under vacumn, normal water hose should be fine.
Richtiger
posted on 8/11/08 at 04:51 PM |
yea found what im looking for thanks a lot for your help. flea bay is a wonderful place sometimes. yea im 22 was sick of hearing bout maths youll
never need at school so shut my ears. maybe shud have picked up few more of the relavent bits to life but what can you do.
adithorp
posted on 8/11/08 at 08:03 PM |
"...so what i measured is 3/9 in"
No, what you measured was 3/10"
What you want is 8mm or 5/16"
adrian
http://jpsc.org.uk/forum/
