<<  1    2  >>
Author: Subject: Decent BHP calculator
nathanharris1987
posted on 9/11/08 at 05:41 PM Reply With Quote
Does anybody know of a half good BHP calculator that you can work out how much you loose through your drive train to give BHP at the wheels?
Ive had a scan but all i can find is small calculators that tell you your power to weight per ton answer!?
ta
nath
iscmatt
Contributor
Posts 1929
Registered 30/3/06
Location York
Member Is Offline
Photo Archive Go!
Building: - BUILT - 2.0 pinto indy, Kent Cam, zzr1100 carbs
posted on 9/11/08 at 05:43 PM Reply With Quote
does this not depend on each individual cars mechanical resistance?
philw
posted on 9/11/08 at 05:48 PM Reply With Quote
I usually budget for a 20% loss.
Must try harder
nathanharris1987
posted on 9/11/08 at 05:49 PM Reply With Quote
well yeh but if youve got a certain ratio diff, certain ratio box, sized wheels, weight, engine power surely you can get a "fairly" accurate idea of what your cars got without getting it dyno'd?
mr henderson
Rolling roads normally extrapolate the flywheel bhp by measuring the power train losses (including the tyres) on the over-run after doing a power run, so I doubt there is a standard ration available for estimating these losses
John
C10CoryM
posted on 9/11/08 at 05:51 PM Reply With Quote
This actually ends up being a fairly complex calculation. You need to know the rotational inertial of all rotating parts which is pretty hard to calculate. At least it was to me .
General rules of thumb is about 10% driveline lose for a manual trans, and about 15-20% for an automatic.
"Our watchword evermore shall be: The Maple Leaf Forever!"
dinosaurjuice
posted on 9/11/08 at 05:55 PM Reply With Quote
depends on transmission, oil type, tyre type, tyre temperature, pressure, weight on back axle, list is endless..... a true 'at the wheels' calulation should also take into account the drag of undriven wheels, as this is a constant.
BHP figures are only good for pub talk
is the car fast enough for you? thats all that matters IMO.
dinosaurjuice
posted on 9/11/08 at 06:04 PM Reply With Quote
whoah, 4 posts in the time it took me to write 1! you guys type fast!
mr henderson
posted on 9/11/08 at 06:44 PM Reply With Quote
Originally posted by chris mason
I was always lead to beleive that RR's measured the torque at the wheels, it then used this info to calculate the bhp at the wheels and then took a guess at the flywheel figures.
Chris
They don't need to guess they can measure the losses. When the power run finishes the operator lets the road slow down while the car is still in gear. The machinery can then mesure how much power is being lost (including the tyres which is usually where most of the losses occur IIRC
John
v8kid
posted on 9/11/08 at 08:47 PM Reply With Quote
% figures seem to be OK mine worked out at 11.1% on the rolling road with a higher horsepower than the transmission was designed for so I'd say it was a % thing rather than a fixed figure.
mr henderson
posted on 9/11/08 at 09:12 PM Reply With Quote
Can't see that myself. It must take a fixed amount of power to turn a transmission, set of tyres, joints etc at a certain speed, how would those things be relevant to how much power the engine was m?
John
andyharding
posted on 10/11/08 at 08:53 AM Reply With Quote
Can't see how it can be "measured" without disconnecting the engine from the drive train. For example resistance will be created by a closed throttle and subsequent increase in vacuum that would not be present during acceleration.
mr henderson
posted on 10/11/08 at 10:23 AM Reply With Quote
Perhaps he uses the clutch? It's a while since I've had a car on the rollers, but thinnking about it now, if he was to finish the power run and put the clutch down then the equipment would be able to measure the power losses up to the flywheel
John
C10CoryM
posted on 10/11/08 at 02:53 PM Reply With Quote
Using a percentage is not accurate. It is just a guess. As is any horsepower number you hear unless you have been on a dyno (engine or wheel).
However, 10-20% usually works because if you have a weaker engine, typically the driveline parts are lighter.
On the wheel dynometer (rolling road?) you are only measuring the wheel horsepower and torque. If they are giving you flywheel horsepower as well, is just a guess (probably using 10-20% driveline loss ). If you want to know flywheel hp you need to run it on an engine dyno.
One more thing of note. I've seen as much as 15whp difference on dynometers depending on brand. Meaning one brand will always read higher.
Cheers.
mr henderson
posted on 10/11/08 at 03:44 PM Reply With Quote
For the third time on this thread!!!!!
They do not need to guess, they can measure the driveline drag after the power run.
OK, it may not be as accurate as an engine dynamometer, but seeing as engines are usually run in cars rather than on dynos, engine dynos aren't very relevant anyway.
So, let me just repeat, again, flywheel figures from a rolling road are not guessed, or arrived at using a percentage, they are deduced by adding the braking effect of the driveline and tyres MEASURED by the RR, to the power figures obtained during the power runs
John
philw
posted on 10/11/08 at 04:25 PM Reply With Quote
John
The op's original post was asking for a decent calculator, the only way of an accurate figure is as you say an RR session, i piped up with 20% loss which is a fair guess, my car 185@ fly 150 at wheels, a friends car 210@ fly 170 at wheels, as i said only a guess and it will vary different with set ups but with a 20% guess you wont be too dissapointed.
Must try harder
mr henderson
posted on 10/11/08 at 05:37 PM Reply With Quote
John
I have no argument with that, apart from the clear implication that the losses between flywheel and road are a percentage of the total output. They are not. To provide an eaxample, if an engine's output was to be suddenly doubled, but the rest of the car was to stay the same, why would the losses need to go up? There's just no reason for it.
So, while I will agree that a guess of losses in the region of (in your example) 35bhp might be reasonable, I won't agree that those losses are a proportion of the engine's output
John
C10CoryM
posted on 11/11/08 at 03:15 AM Reply With Quote
I guess your dynos are fancier than ours as I have never seen that here. You typically don't get flywheel readings. What dynometer are you using?
It also would not take into account slippage, but on most locosts that shouldnt be an issue.
posted on 11/11/08 at 08:58 AM Reply With Quote
Transmission loss as measured by a rolling road are at best a rough approximation, they are never accurate. You are driving the entire drivetrain backwards for starters, so all the gears will be using the wrong thrust face, and helical gears will be producing thrust in the opposite direction to normal. The tyres play a huge part in the loss on a rolling road as well, much more so than on the road.
Transmission loss is neither a percentage of total power, nor a fixed number, but a combination of both. A higher power engine is going to show more loss through the same transmission than a lower powered one, but it won't be proportional.
[Edited on 11/11/08 by MikeRJ]
mr henderson
posted on 11/11/08 at 09:07 AM Reply With Quote
Well, power figures are basically used for comparison purposes and, perhaps unfortunately, the comparisons in the UK tend to be with flywheel figures. It's desirable, therefore, that rolling roads provide flywheel figures. I guess the equipment over there could also do that but maybe it just isn't needed, as I understand whp (wheel horsepower) is the standard measure in North America.
There's a good descrition of how a typical UK rolling Road works here (written by Dave Walker)
http://www.emeraldm3d.com/em_r_road.html
John
mr henderson
posted on 11/11/08 at 11:35 AM Reply With Quote
Well then it's a good job that the rolling road measures the tyre losses too!
Why would a more powerful engine show higher losses throught the same transmission? I'm not saying that it wouldn't, but I see no inherent reason why it would, so would be interested to hear your thoughts about that.
Also, in your quote above, you start by saying that the power losses are partly a percentage of the total power, how can that be? (in effect the same quetion as I asked above)
John
v8kid
posted on 11/11/08 at 12:02 PM Reply With Quote
I may be wrong but it is reasonable to suppose that gear losses are in part frictional and frictional liosses are proportional to load. It takes more effort to push a heavy wheelbarrow than an empty one.
Part of the losses will be due to the oil sloshing around in the gearbox getting chewed up by the gears and I think it is reasonable to assume that these losses would be proportional in some way to the speed of the gears. I would hazard a guess that the loss is proportional to the square of the speed - most power things are.
There will be some bearing losses, tyre losses and if you want to get really into the nitty gritty some inertial losses.
How much of each there is I havn't a clue! oil losses can be significant though thats one reason why dry sumps are fitted ans tyre losses are also significant - withess the chunks of rubber that are flung off them on the rolling road.
I bet a third each and would be suprised if I am far wrong.
Remembering that to get more power we usually up the revs the power loss should not be far off proportional to the input power.
If you can be arsed searching there are loads of academic papers on the subject
v8kid
mr henderson
posted on 11/11/08 at 12:21 PM Reply With Quote
I agree that if equipment is run faster then the losses would increase too, however the rolling road will be measuring power output at specific speeds, so the question of the gears etc running faster doesn't really arise.
I've been thinking about this a bit, and I think a quite decent analogy would be raising water in a well, by use of a winch. Naturally there would be power losses in the winch, but the analogous effect of a more powerful person raising the water would be a bigger bucket rather than a quicker lift, therefore I don't see any particular reason why the power losses should be proportional to the strength of the person.
John
v8kid
posted on 11/11/08 at 03:22 PM Reply With Quote
John read the bit where I said the friction losses were proportional to the applied load. Think about pushing heavy versus light loads across a gravel drive.
<<  1    2  >>
