Author: Subject: how do i weld titainium to stainless ????
indyian
posted on 12/11/08 at 10:11 PM Reply With Quote
as above i been making my exhaust and come across a problem i cant weld my new stainless link pipe to my modified r1 can because its titainium what can i do any ideas please many thanks ian
nitram38
posted on 12/11/08 at 10:13 PM Reply With Quote
With pop rivets!
As far as I am aware, unless there is a dissimilar metal ( a rod that welds to either) you will have to make a mechanical join.
ashg
posted on 12/11/08 at 10:14 PM Reply With Quote
i believe you should be able to tig it with tiatnium filler rod not sure what grade though. will ask next week at my tigwelding course if you can wait.
Haynes Roadster (Finished)
Exocet (Finished & Sold)
New Project (Started)
dubstar_04
posted on 12/11/08 at 10:17 PM Reply With Quote
Explosion weld it!!!
Probably not something you want to try in your garage but its still interesting!!
Explosion welding
blakep82
posted on 12/11/08 at 10:18 PM Reply With Quote
think someone had a thing on here about a similar problem a few weeks back. think the answer was no...
if the titanium end cap is riveted on, can it be removed, and something from here http://www.pjengineering.co.uk/products.asp?cat=10 riveted on instead? then welded to the down pipe?
________________________
maximill666
posted on 12/11/08 at 11:38 PM Reply With Quote
Unfortunately you cannot fusion weld Titanium to stainless steel.
You would need to weld a titanium link pipe to your R1 can
Regards,
Lee.
iank
posted on 12/11/08 at 11:50 PM Reply With Quote
Previous thread
http://www.locostbuilders.co.uk/viewthread.php?tid=98440
Anonymous
