Author: Subject: Vacuum forming help needed.
smart51
posted on 13/11/08 at 07:21 PM Reply With Quote
I've had a go at vacuum forming today but without much success. I heated the oven to the desired temperature (160° for acrylic) and waited for the plastic to sag, the put the vacuum cleaner hose into the hole in the box I made to hold the mould and, well, not very much.
I pushed the plastic into the mould with the handle of a spoon that had been sat in a cup of boiling water and the plastic moved a bit but it wasn't at all like you see on TV.
Howlor
posted on 13/11/08 at 07:25 PM Reply With Quote
What thickness acrylic were you using?
smart51
posted on 13/11/08 at 07:27 PM Reply With Quote
2mm. Quite thin really.
Howlor
posted on 13/11/08 at 07:29 PM Reply With Quote
I would say try 180ish, but I would have thought it should have gone at 160. Did you trap the outer edge of the acrylic to form the seal?
smart51
posted on 13/11/08 at 07:33 PM Reply With Quote
The acrylic is clamped between 2 plywood squares with the middle cut out using 6 bolts set into one of the frames and wing nuts to hold on the top.
The baby is in bed now but I'll have another go tomorrow.
How many holes should I have in the mould and how big should they be? For info, the box is 410mm x 425mm on the outside (just fits in the oven).
Howlor
posted on 13/11/08 at 07:37 PM Reply With Quote
You need enough holes to let the vac pull it's full vacuum. I would say 8 x 6mm spread across the tool to allow for even pull.
You could put a solid sheet in with say a small hole to put your finger over just to check that you have a good vacuum.
SeaBass
posted on 13/11/08 at 07:43 PM Reply With Quote
I'd suspect that your vacuum cleaner is not able to evacuate the box or you have a leak allowing equalisation of pressure...
James
Howlor
posted on 13/11/08 at 07:57 PM Reply With Quote
TBH I know of a lass that could do the job for you. I reckon she could suck golf balls through a hose pipe!
nathanharris1987
posted on 13/11/08 at 08:48 PM Reply With Quote
what what? how do you know my ex?
emsfactory
posted on 13/11/08 at 09:18 PM Reply With Quote
Probably not hot enough. You dont need much pull to draw over a buck if the plastic is hot enough.
smart51
posted on 13/11/08 at 09:36 PM Reply With Quote
How do you tell if the plastic is hot enough then?
Hammerhead
posted on 13/11/08 at 09:44 PM Reply With Quote
the plastic should sag, then re tighten in your frame, this means it is ready to form.
You need a lot of holes, I used 3mm drill bit.
Raise your mould off the board slightly with a spacer of a couple of mm, this allows air to get under the mould.
Make sure your frame seals with your base board, dont let air escape.
I used a shop vac which is a very powerful american vacuum cleaner, but my mould was 250mm deep.
Check that your vac doesn't have a safety pressure release valve, (dysons do) this safety feature stops people having their men bits sucked clean off if they happen to 'fall on the vacuum cleaner whilst hoovering naked'
Hope that helps.
trextr7monkey
posted on 14/11/08 at 12:35 AM Reply With Quote
Hi Smart, we have a vac former at work what size is your mould, without frame etc? I fit will fit in we can prob knock you one or 2 out
atb
Mike
Mr Whippy
posted on 14/11/08 at 07:47 AM Reply With Quote
I'm a bit confused what the spoon is for, never needed one or anything like that when I do this.
From what I can read, you may not have sufficient holes, an A4 sized area should have around 100-200. Plus it does not sound like you have put foam draught seal around the edge of the box for the frame to press against, this is quite important due to the low flow rate of the air being drawn through all the holes.
The sheet is hot enough when it is floppy when the frame is rocked, then press the sheet down on the mould in one go, till the frame seals against the box with the draft seal foam, then the vacuum will completed the process. Even a small air leak will prevent it working so make sure the box and frame are air tight.
A photo of what you have built would solve the issue very quickly btw
Don’t give up as you will find this process invaluable around the scooter in areas like the dash etc and its well worth learning how to do it.
posted on 14/11/08 at 07:55 AM Reply With Quote
how do you know it was 160? did you rely on the cooker dial or use an accurate thermometer?
Mr Whippy
posted on 14/11/08 at 08:22 AM Reply With Quote
I find using a hot air gun far better than an oven, held about a foot away and moved more around the edge of the frame than the center. Its great if one area is stiffer than the rest and if it starts to droop too much you can flip the frame over rather than the risk that the plastic might touch the inside of the oven and get ruined. I sit the frame on the backs of two wooden chairs so I can heat the underside as well.
[Edited on 14/11/08 by Mr Whippy]
smart51
posted on 14/11/08 at 04:10 PM Reply With Quote
I've had another go with more sealing on the box. There are 2 problems. 1 is that the plastic sags so much in the oven that there is too much material to be pulled into a shallow mould, so the edges are raised off the mould in places. 2 is that it doesn't pull into the corners of the mould at all. The radius it forms too is quite large.
I now have a fairly large plastic bowl where I just let the scrap piece sink in the oven then let it cool.
The plastic didn't sag then tighten up, it just sagged. A lot. How do I get it hot enough without sagging too much?
hellbent345
posted on 16/11/08 at 10:38 PM Reply With Quote
just heat it less, the perfect temperature is when you can stab it with a finger (not too much) and its soft enough to absorb the blow, but soft of hard enough to spring back to flatness
