Author: Subject: spare wheel
A1
posted on 5/12/08 at 12:44 PM Reply With Quote
spare wheel
do you need one for sva or mot? or do you need that foamy stuff?
Mr Whippy
posted on 5/12/08 at 12:47 PM Reply With Quote
no for both
I always take spare wheels out for MOTs as then that way I can't fail on it
[Edited on 5/12/08 by Mr Whippy]
omega0684
posted on 5/12/08 at 12:50 PM Reply With Quote
DAM YOU Whippy your so quick ! up to nothing at work again today?
Mr Whippy
posted on 5/12/08 at 12:57 PM Reply With Quote
what do you mean? It took me 3 minutes to reply to that one cos I was making my coffee...can't work anyway as I have several large boxes in the way
adithorp
posted on 5/12/08 at 01:05 PM Reply With Quote
Spare tyre is not part of SVA or MOT nor is there any legal requirement to carry one.
no for both
Why take it out? It's not part of the test. The only way you could get a fail would be if it was slung under the car and the carrier wasn't secure.
adrian
http://jpsc.org.uk/forum/
Mr Whippy
posted on 5/12/08 at 01:22 PM Reply With Quote
no for both
adrian
Just looked it up on the web, appears you are correct
dinosaurjuice
i was under the impression if a spare wheel was present and not legal i.e. insufficent tread, the car would fail. because in the event of a puncture its likely the owner will use it.
i might be wrong.... but thats what 'i heard'
will
edit: ive heard wrong!
[Edited on 5/12/08 by dinosaurjuice]
Mr Whippy
posted on 5/12/08 at 01:24 PM Reply With Quote
will
so was I but this, taken off the Mot web site -
Tyre condition
A failure with respect to tyre wear will result where:-
The grooves of the tread pattern are not at least 1.6mm throughout a continuous band comprising:
• Central 3/4 of the breadth of tread
• Entire outer circumference of the tyre.
Tyres must be correctly matched with regard to:
• Type
• Size
• Structure
• Location on the vehicle with respect to the axles.
Also examined:
• General condition of tyre
• Condition of valve
Tyres fail if they have serious cuts, bulges or other damage. The wear on the tyre is checked with a tyre tread depth gauge to ensure compliance. The tyres are examined to ensure that there is no fouling with any part of the vehicle.
More.. | Top of Page
Note: The condition of the spare tyre is not part of the MOT.
Wheel condition
Inspection to reveal:
• Damage
• Distortion
• Cracks
• Distorted bead rims
• How securely attached to the vehicle
• No wheel-nuts or studs missing
An externally fitted spare wheel or spare wheel carrier must not be so insecure that it is likely to fall off
Humbug
posted on 5/12/08 at 01:39 PM Reply With Quote
Slightly O/T but although I have got a spare wheel I don't have it on my car because I have no carrier (!)... I do carry a can of foam, which I needed to use a couple of weeks ago. It did the trick and I was able to get the tyre repaired the next day
mistergrumpy
posted on 5/12/08 at 01:43 PM Reply With Quote
Can you repair tyres that've been filled with foam? I thought it just clags everything up and the tyre had to be chucked.
Vindi_andy
posted on 5/12/08 at 01:51 PM Reply With Quote
AFAIKR the spare in an unroadworthy condition is not a fail but will be noted as an advisory.
Stantman
posted on 5/12/08 at 03:13 PM Reply With Quote
Honda accord estate, No spare tyre supplied, just a compressor and a can of foam. So assume that its not required for MOT or I will have to have a chat with Honda. Yes thats the end of the tyre, its not repairable after foam used according to my local tyre place.
Humbug
posted on 6/12/08 at 11:22 AM Reply With Quote
Well, I took my tyre round to the tyre place and thay asked how long the foam had been in there. When I said 1 day they went ahead and did the repair... maybe after a certain time it sets too hard to be washed out?
...or are "foam" and Tyreweld different things?
In any case, they repaired my tyre in the normal way and so far so good
posted on 6/12/08 at 01:31 PM Reply With Quote
As already stated an illegal spare is not part of an MOT test just an advise BUT if you are stopped by the police you can be prosecuted . IIRC the charge would be intent to use an illegal tyre? PS if the tyre is flat you cannot be done.
[Edited on 6/12/08 by rusty nuts]
mad-butcher
posted on 7/12/08 at 08:33 PM Reply With Quote
Just nit picking
"isnt it only an offence if the tyre is being used "on" the vehicle otherwise it would be on hell of a fine for those 35 tonne wagons that collect scrap tyres?"
Tony
