FastBarney
posted on 15/12/08 at 08:48 PM |
Crazy Tacho
hey
my tacho is doing crazy things
when i am driving my car and accelerate to 4000 rev the tacho is going to end of the tacho 7000 revs then getting to 0. then it's go to the
normal revs. When i am driving slowely and not accelerate hard the tacho worksfine.
When i rev teh engine when i am not driving , just stationairy the tacho works fine. It seems he has got it only when i am driving the car.
I am using diodes between the tacho and ignition to get it working.
It's not the tacho.because i used a mate's one and its the same.
somebody a clue what it is.
Components are ok , tacho ok.
i don't know there is nothng between.
maybe something is wrong on my ignition?
cheers melvin
paulf
posted on 15/12/08 at 09:09 PM |
What ignition system are you using? is it wasted spark with a coilpack such as Megajolt?.If you are using Megajolt then it is possible to use the pip
signal from the Edis module , this usually works better than trying to get a good signal from the coilpack.
Paul.
mediabloke
posted on 15/12/08 at 09:13 PM |
^^^ What he said. My tacho was all over the place over about 2k, until I moved the input feed from the MJ tacho feed to the PIP.
Danozeman
posted on 15/12/08 at 09:25 PM |
Which wire is the pip on the edis? MInes crap too!
Dan
paulf
posted on 15/12/08 at 09:36 PM |
Pin one on the edis module.
Paul.
FastBarney
posted on 16/12/08 at 05:45 AM |
i am using the original ford zetec ignition
original ecu and coilpack.
thepest
posted on 16/12/08 at 07:00 AM |
Wait guys why would a normal rev counter read a signal from the PIP? doesn't it need a high voltage kickback from the coil or similar?
P.S. My Tach does the same sometimes
FastBarney
posted on 16/12/08 at 04:52 PM |
but a time a go he didn't go crazy mine.
my tacho is ok; test it with a other one from a mate, same probem.
Diodes are ok ; replaced them to be sure.
so the only thing is that it could be is that the signale is wrong when i drive it.
Tomorrow i will try a other coilpack and sparkplugcabels. i have a spare set. maybe teh problem is somewhere there. i will let ypu know tomorrow.
cheers melvin
mediabloke
posted on 16/12/08 at 11:01 PM |
similar?
Not necessarily. It seems to depend on the type of rev counter. Most aftermarket rev counters take a switched low-voltage input.
quote: ETB (who made my gauges) say:
"4. Connect Pin 4 (signal input wire) in either of two ways:-
a) For conventional distributor based systems, the signal wire should be connected to the negative (-ve) side of the ignition coil.
b) Engines using electronic ignition modules that have their own output wire for a tachometer should be used to provide the input signal for the
tachometer."
As the PIP provides a 1-pulse-per-revolution, I found it a more reliable trigger than either a diode bridge or pull-up resistors.
thepest
posted on 16/12/08 at 11:29 PM |
what the hell, I'll give it a go
FastBarney
posted on 17/12/08 at 08:18 PM |
changed the coil pack and sparkplugcabels
and didn't help
He already did it when i was driving from my driveway.
Anybody got a idea?
cheers melvin
paulf
posted on 18/12/08 at 04:31 PM |
Connect the rev counter to pin 1 on the Edis module , many people have had the same problem and this usually works no need for any diodes etc.
Paul.
and didn't help
Anybody got a idea?
cheers melvin
FastBarney
posted on 18/12/08 at 05:32 PM |
hey
i don't have a edis module
i have a ecu. found that there is a tachometers signal that comes from the ecu.
but the signal is to small it is only 0,3 volts.
will try to get it up
and see what that will give
cheers melvin
Macbeast
posted on 19/12/08 at 08:53 AM |
Ummmm...
What is a PIP ?
Does a tacho work off the Greenwich time signal ?
( sorry )
