Author: Subject: IS this prop setup ok?
garage19
posted on 20/12/08 at 09:49 PM Reply With Quote
This is mocked up with and extended BMW prop
Both engine and diff flange are paralell.
Prop from engin to centre bearing will have a slider in it.
Prop from centre bearing to diff is not straight. Is this ok?
Does the centre bearing need to be at 90 deg to the back prop rather than paralell with the diff flange?
A1
posted on 20/12/08 at 10:11 PM Reply With Quote
i would think it should be okay...i dont think my prop is perfectly straight...as long as all the joints work well!
clairetoo
posted on 20/12/08 at 11:10 PM Reply With Quote
As I understand it , the engine and diff flanges need to be parallel with a one-piece prop - dont know how this works with a two piece prop ?
Its cuz I is blond , innit
Claire xx
Will weld for food......
colt_mivec
posted on 21/12/08 at 12:04 AM Reply With Quote
What shell is it fitted in?
ashg
posted on 21/12/08 at 01:02 AM Reply With Quote
looks fine to me but make sure the middle bearing is well secured as that will be where it lets go if its not right
Haynes Roadster (Finished)
Exocet (Finished & Sold)
New Project (Started)
garage19
posted on 21/12/08 at 08:18 AM Reply With Quote
A Chevette!
Danozeman
posted on 21/12/08 at 02:42 PM Reply With Quote
Surely the slider needs to be between diff and centre bearing? As the slider takes up movement of the axle going up and down? Engine to brg surely wont move in and out?
As for the setup a u/j doesnt want to be dead straight anyway so it should be ok.
A chevette should be a beast!!
Dan
garage19
posted on 21/12/08 at 02:45 PM Reply With Quote
It has an E30 bmw rear end in it, not the normal live axle.
garage19
posted on 24/12/08 at 10:47 AM Reply With Quote
Up for anymore opinions.
sucksqueezebangblow
posted on 24/12/08 at 11:12 AM Reply With Quote
Angled is okay (standard on my Busa Vortx) but try to keep the rear section of the prop (to diff) parallel. Output flange on mine is off-set and angled slightly. Slider at the front (with a fixed diff) is also okay as on mine.
carpmart
posted on 24/12/08 at 12:34 PM Reply With Quote
A Chevette!
Ah! I now know why this appeared 'familliar' to me, I've seen your resto thread on Turbosport!
The prop look fine from the pic and your description!
'94 MX5 MK1, 1.8
F10 M5 - 600bhp Daily Hack
Mercedes A class - Son's Car
