Author: Subject: x20xev sump, g'box oil and diff oil
blakep82
posted on 24/12/08 at 03:29 PM Reply With Quote
1) since the vauxhall ecotec block is the same as the c20xe, are the sumps interchangable? looking at my car with the engine in, i think the sump will need to be shortened. could i buy a shortened sump for a c20xe and fit it right on? or will the oil pick up pipe need to be modified? or should i just avoid speed bumps?
2) whats the best oil to have in my type 9 box?
3) as above for my full floating atlas diff? and whats the capacity of a standard atlas diff? to to give a guide as how much oil i'd need for it
thanks guys, i know you lot know pretty much everything ever
[Edited on 24/12/08 by blakep82]
________________________
liam.mccaffrey
posted on 24/12/08 at 03:35 PM Reply With Quote
yes,i believe the sumps are interchangeable, unless the oil pickup is different. I haven't checked.
[Edited on 24/12/08 by liam.mccaffrey]
Build Blog
Build Photo Album
chrsgrain
posted on 24/12/08 at 04:02 PM Reply With Quote
I've got a spare XE sump you can have for cost of postage if its any good to you?
Chris
posted on 24/12/08 at 07:06 PM Reply With Quote
Hypoid EP80 gearbox oil and EP90 final drive. The level is just below the filler hole, can't be more than 2ltr at a guess.
[Edited on 24/12/08 by Peteff]
blakep82
posted on 24/12/08 at 07:49 PM Reply With Quote
as much as 2 litres?! i guess thats the gearbox. i think the axle will take MUCH more than that especially at about £10 a litre....
thanks for the offer chris! I'll bear it in mind. i'll keep it standard for now. see how long it lasts
