Author: Subject: English live axle Disc conversion kit
ChrisGamlin
posted on 2/1/09 at 10:12 PM Reply With Quote
Rear disc conversion kit for English Axle, includes discs, calipers (from a 206 I think), pads, mounting brackets and handbrake cables. £125
Collection (from Hants) preferred due to weight but could be posted at cost. Payment by bank transfer preferred, or Paypal if you pay the fee
Dangle_kt
posted on 3/1/09 at 12:27 PM Reply With Quote
Is it just a bolt on jobbie? any complex stuff involved in disasembly of drum, or fitting the disc kit?
posted on 3/1/09 at 12:57 PM Reply With Quote
You usually have to get the drive flanges machined down a bit to fit inside the discs.
ChrisGamlin
posted on 3/1/09 at 01:58 PM Reply With Quote
Not sure as Ive never got round to trying to fit it. I'll check with a couple of spare half shafts Ive got.
cheers
Chris
posted on 3/1/09 at 04:03 PM Reply With Quote
The brackets will fit an Atlas Capri type axle as well. The flanges need about 3mm off them to clear if you use Fiesta discs. You need to pull the half shafts to get the back plates off.
[Edited on 3/1/09 by Peteff]
ChrisGamlin
posted on 4/1/09 at 11:34 AM Reply With Quote
Cheers Pete, didn't know they'd fit both
ChrisGamlin
posted on 6/1/09 at 10:10 AM Reply With Quote
I've checked and the discs DO fit over standard halfshaft drive flanges without any mods/machining required. i have a couple of pics which I'll upload tonight when I get home.
Dangle, to answer your question properly though, the drums come off very easily once you've withdrawn the half shaft (they fall off!), so you'd just need to check brake line lengths etc to the new calipers. The new caliper brackets bolt on using 3 of the 4 bolt holes used to hold the half shaft and old drum in position, it may need longer bolts to do this which I don't think are in the kit but they're fairly standard sized bolts (M10 I think) you could get from a nut and bolt place quite easily, I might even have some in my nuts and bolts drawers that would be suitable.
I guess the trickiest bit may be sorting out the new handbrake cables, but if you've already got separate cables running to each wheel (rather than one cable and a metal bar actiaving the other drum like standard Escort setup) I suspect they'd work anyway
cheers
Chris
[Edited on 6/1/09 by ChrisGamlin]
