Humbug
| posted on 12/1/09 at 11:20 AM |
NTDWM black double bubble aeroscreens £45
He's back on
ebay with these for £35 buy it now + £9.99 P&P. 7 available
at the time of posting this.
I've got one and several others on here and I can recommend it.
nib1980
| posted on 12/1/09 at 11:33 AM |
does it fit on your Stuart taylor ok, or does it need modifying?
Danozeman
| posted on 12/1/09 at 01:05 PM |
Do these fit a velocity scuttle?
Dan
Humbug
| posted on 12/1/09 at 01:14 PM |
Linky to the trhead where I describe fitting it
to the ST. In short, I didn't modify the screen at all, but it does end up leaving a small gap where it goes over the ledge on the ST scuttle. I
filled the gap with some rubber trim and silicone, and it is hardly noticeable unless you look at it from close up below the screen.
Re Velocity: I think it should fit most scuttles, as it is fairly flexible. If the Veocity scuttle has a ledge/step you will have the same issue I did
- just depends if you can live with it.
Simon
