Author: Subject: Netto Hoist
zilspeed
posted on 13/1/09 at 09:38 PM Reply With Quote
Netto Hoist
Like the one I have.
Fantastic value.
Netto Hoist - £39.99
This Thursday - 15th January
sprouts-car
posted on 13/1/09 at 10:10 PM Reply With Quote
Lifting Weight: 125Kg - 250Kg
How does that work then? It cant do 100Kg?
posted on 13/1/09 at 10:13 PM Reply With Quote
I have one of them and I've lifted zetec's in and out no problem. It has a loop hook to increase the lifting weight
Z20let Corsa
posted on 13/1/09 at 10:22 PM Reply With Quote
i got one of these about 2 weeks after xmas for £17.50!!! from netto. it lifts the rover v8 with gbox no probs!!!
dave1888
posted on 13/1/09 at 10:30 PM Reply With Quote
going to have one of those
dhutch
posted on 13/1/09 at 10:39 PM Reply With Quote
Looks very much like this, which we bought one of a while back.
- We use it to lift a boat against the garage roof, but its s decent bit of kit.
As said, the two numbers are its two rated lifting amounts. Depending if you use the pulley to double it over or not.
Daniel
zilspeed
posted on 13/1/09 at 11:02 PM Reply With Quote
Remember they're England only shops Dave.
Hopefully you have some reason to be down there and can pick one up. Then you can do the Zil Mod for a cost of around £20. Makes it so much more useful, especially when you start howking that new engine in.
P.S. If you still have the welder to get sorted out, I can do the trolley for you if you decide you want to do the whole gantry thing.
dave1888
posted on 14/1/09 at 06:04 PM Reply With Quote
I cant get one up here.
zilspeed
posted on 14/1/09 at 06:28 PM Reply With Quote
Maybe get someone to send one up for you ?
cloudy
posted on 15/1/09 at 12:04 PM Reply With Quote
You can run them in single cable or double cable mode (half's lift distance - but still will do the height of the garage) The rating is for each mode
www.warnercars.com
