Author: Subject: Lots for sale, some free
Lars
posted on 24/1/09 at 05:50 PM Reply With Quote
I have various bits and pieces for sale, to fund upgrades.
Propshaft from Autoprop UK. 84cm long in total. Goes from a type nine to an english axle (small flange). Only used for a couple of hundred miles, £80
Image deleted by owner
ST170 mounting rubbers. £10
A pair of Sierra rear discs, hubs, calipers and half a drive shaft. Fresh from the scrapyard, removed from a sierra 4x4. £50 (only wanted the diff, but had to take the whole axle)
Remainder of sierra arms that hold the hubs. (from a drum braked sierra) I thought people who want to make their own rear uprights might be able to make use of this. Free of charge, of course.
Facet fuel pump used to fill my swirl pot. 8mm entry and exit. I will leave on the 90degree bend and also include the original filter element inlet that is originally included. £15
Fuel tank made from 2mm aluminium. (size is height 25cm, length 60cm, width at bottom 20 cm, width at top 15cm). It has a 2" filler hole, a 8mm and a 3/8" inlet on the drivers side (ideal if you need a return with an EFI system). I have cut a hole for a TIM fuel sender and fitted this with rivnuts (size of hole is aproximately 30-35mm, will measure tomorrow when I remove the tank. There is also a breather on top. (again from memory this is 8mm, but can measure tomorrow). £50
I will also throw in the swirl pot that I used to run my EFI system. This was welded up by myself in mild steel.
(Note that both swirl pot and tank are currently still in the car, when you buy this you will only get the bare tank and swirl pot all other attached parts will be removed)
2x 60mm exhaust clamps £3
flexible coolant hose lengths of 68cm 19cm and 14cm, this can be cut to size, diameter stated as 1.25" to 1.375" £10,
flexible exhaust joint 2" diameter 10cm long £10
I am also looking to sell my english axle, which has a rare 3.77 ratio.
The axle is generally in a good condition and has recently been used to pass SVA.
It does need fitting of a new wheel bearing (included).
It also leaks some oil from the pinion seal.
I have drilled a small hole in the nearside backplate and tacked a nut onto the hole in the hub, to allow fitment of a speed sensor and magnetic bolt. £sensible offers.
I would prefer collection, but I am happy to post the smaller items.
Any questions please let me know.
Lars
carlknight1982
posted on 24/1/09 at 06:25 PM Reply With Quote
u2u re tank
Lars
posted on 26/1/09 at 09:12 PM Reply With Quote
bttt
If there are no takers the items will make an appearance on the bay
Lars
HOL
posted on 29/1/09 at 01:22 PM Reply With Quote
If I had an LSD already, id have have the halfshafts off you as I want to replace my cortina axle.
They most be perfect for anyone updating to rear disks though.
How are fitting the sierra diff to your booK chassis Lars?
Free Btt.
[Edited on 29/1/09 by HOL]
Daddylonglegs
posted on 29/1/09 at 02:00 PM Reply With Quote
u2u re: prop
ryanslaney
posted on 29/1/09 at 03:41 PM Reply With Quote
u2u re- shafts, discs, hubs, callipers etc..
Krismc
posted on 29/1/09 at 06:40 PM Reply With Quote
ST170 Mounts please, long as they come with jubliee clips!
Norledge
posted on 2/2/09 at 03:12 PM Reply With Quote
u2u for tank and pump
www.built4track.co.uk - cheap track days and the like!
thefreak
posted on 30/3/09 at 09:18 PM Reply With Quote
Is the prop still for sale?
