scutter
posted on 9/2/09 at 03:56 PM |
Tyre buffing
Does anyone know of a company who does tyre buffing in the Oxfordshire area?
I'm led to believe that it'll pay to get my new Yoko's buffed down before using them in anger.
ATB Dan.
matt_claydon
posted on 9/2/09 at 04:11 PM |
Sorry, can't help with the question, but if you want tyres with most/half of their tread gone, the locost way it to buy part-worns; same end
result! Buffing seems like a waste of good rubber to me
JUD
posted on 9/2/09 at 04:20 PM |
Wait for the snow to go and then head out to your nearest Sainsbury's carpark... Rotate front to back halfway through carpark hooning session
and bob is your proverbial horse's aunt.
MK Indy Blade
pewe
posted on 9/2/09 at 05:06 PM |
Dan, thought you had your own (perimeter) track to scrub them in?
Cheers, Pewe
scutter
posted on 9/2/09 at 05:46 PM |
Das Police has something to say about the carpark donuts!!, mine it's the same on the peri-track at the mo, mind it's more of an ice rink
presently.
I've used about 2mm of tread in 3years and 20,000 miles I can't wait that long for the tryes to come in.
Part worns, might be a good idea, I'll have to look into them. Still no suggestions for buffing services though!!
ATB Dan.
Ninehigh
posted on 9/2/09 at 09:40 PM |
Hold on, you'll pay for someone to wear your tyres out? I'll do it for free if I get the car for a bit with it
Seriously though part worns are about a tenner each
scutter
posted on 10/2/09 at 07:44 AM |
OK, part worns are out. It's very hard to find part worn premium tyres (everyone wears them to the bone for good reason) and who wants part
worn S*it tyres, the ones I have would grip better.
Non race tyres last forever on these type of cars (yes I do try hard enough, ask about) so taking a few mm off won't hurt too much.
Ninehigh, many thanks for your kind offer but
ATB Dan.
procomp
posted on 10/2/09 at 09:32 AM |
Hi
The only ones i can think of down your way are the obvious ones like POLLY - Adams&page - tadworth tyres.
Obviously to get the best you need to have new tyres buffed down to 4-5 mm. using S/H ones only means that they are old and the best of the life span
has long since gone. Try asking in the racing section I know most of the 750mc competitors use POLLY or A&P. But there may be some others come to
light.
Cheers Matt
scutter
posted on 10/2/09 at 11:51 AM |
Adams and Page are about 45 mins to an hour from me, I'll give them a shout, Matt your closer than the rest of those people I may have to pop up
your way.
ATB Dan.
[Edited on 10/2/09 by scutter]
C10CoryM
posted on 10/2/09 at 02:53 PM |
Are trying to prevent the tread from "chunking" because the lugs are too deep and overheat on the track?
Or are you just trying to expose some softer rubber?
If the latter, you may just want to try putting a good heat cycle in them. Cna make a huge difference to get rid of the skin on the outside.
Cheers.
"Our watchword evermore shall be: The Maple Leaf Forever!"
posted on 11/2/09 at 09:14 AM |
didn't someone post about some stuff you can paint onto the tread that makes the rubber softer/stickier?
procomp
posted on 11/2/09 at 09:46 AM |
Hi
It will be purely to get the depth of the blocks reduced. Improves the handling no end. Assuming we are talking road tread pattern A539 or the
21's etc.
Cheers Matt
Ps I do not have the facilities to buff the tyres. 99% of the tyres we use come from Polly or A&P who supply them already done.
DarrenW
posted on 11/2/09 at 09:59 AM |
Isnt that something that can put a bit of life back into old sticky tyres that have hardened. I seem to recall it was frowned upon in some race
series.
carpmart
posted on 11/2/09 at 11:02 AM |
Its called Hot Lap or something like that. IIRC, it can be used on new and used tyres
'94 MX5 MK1, 1.8
F10 M5 - 600bhp Daily Hack
Mercedes A class - Son's Car
C10CoryM
posted on 11/2/09 at 02:52 PM |
I didn't know shaving tires helps the handling. I thought it just kept them from "chunking" where large chunks come off from the
tread lugs overheating.
Tire softeners are temporary and will actually make you tires harder and rot afterwards when they cool. Not for street/track use for sure.
Ninehigh
posted on 11/2/09 at 03:05 PM |
What other uses are there?
andrew830
posted on 13/2/09 at 05:33 PM |
i made my own tyre buffer,when we used avons on stockcars we had to buff most of the tread off so they were almost a slick.i bought a big lathe put a
halfshaft in the chuck and bolted the wheel and tyre on.next i mounted a 10mm thick plate on the back of the tool holder so it stuck out the side
nearest the chuck,mounted on the plate was a 3hp motor with a circular saw blade on it.the blade was well guarded!!.i put the lathe going as slow as
possible about 20rpm fire up the saw and send it across the tyre as if you were cutting a thread.it worked a treat
scutter
posted on 13/2/09 at 07:41 PM |
No doubt that worked, but I'm scared from just reading it
ATB Dan.
cjtheman
posted on 13/2/09 at 08:13 PM |
sounds like something out of one of the saw movies
wanted
sunny weather
sva pass 12/6/09
taxed 16/6/09
