foes
posted on 13/2/09 at 11:47 PM |
exhaust exit side panel hole, sharp edges..?
Anyone know if this should pass sva?
the edges in the side panel would obviously fail but i don't think they would be accesible by the 'sphere' that they are checked
with, so should pass..?
[Edited on 13/2/09 by foes]
DanP
posted on 13/2/09 at 11:59 PM |
Mine failed this week on this, even though the sphere couldn't touch the edges I was failed on the rule that sheet metal edges should be bent
back on themselves or trimmed.
Hth
Dan
MikeR
posted on 14/2/09 at 12:12 AM |
copper brake pipe split down the middle and pushed on should sort it and not melt.
Not sure how you split it down the middle - maybe careful angle grinder, but i've heard of someone else doing this.
foes
posted on 14/2/09 at 12:23 AM |
Yeh steve at aries told me that, i got some copper pipe ready (maybe do it with the dremel..?), but was hoping it would pass without
![](/images//smilies/wink.gif)
omega0684
posted on 14/2/09 at 12:54 AM |
i would give at least 1 inch gap between the edge of the side panel and the pipes, you can then use rubber edging and it won't melt
Simon
posted on 14/2/09 at 01:20 AM |
I used ally tube from B&Q, carefully bent to shape, then cut (carefully) with hacksaw.
Push into place, then either glue or ally solder into place.
Simon
James
posted on 14/2/09 at 02:18 AM |
I put 'U' trim on my silencer edges... it's not melted yet!
But then it is the silencer which I guess is cooler.
- Muhammad Ali
The Baron
posted on 14/2/09 at 10:14 AM |
I put normal 'u' trim on mine as well, and it passed ok.
B
gottabedone
posted on 14/2/09 at 11:51 AM |
Either way, you can't cover it up too much as that's a nice piece of work!
foes
posted on 14/2/09 at 12:14 PM |
Cheers..!
Yeh i'm not making the hole any bigger just so i can put some pastic trim on, i'll prob have a go with some split copper pipe.
Unless anyone has passed without trim that is...?
![](/images//smilies/smile.gif)
speedyxjs
posted on 14/2/09 at 12:21 PM |
Id cit the copper pipe with a dremel but be careful it doesnt fall of after SVA
