Author: Subject: Paddle shift and sierra switchgear/column
j-k
posted on 14/2/09 at 10:24 AM Reply With Quote
Morning...
I have used the search facility and looked at loads of photos etc of how to make (or buy) a paddle shift system.
It would however seem that most of the home made jobs and the commercially available units are suitable for the sierra column without switchgear /cowling etc..
I would prefer to keep mine as it is because i dont want any unnecessary switches etc on the dash panel.
Car is an MK Indyblade....
many thanks
jon
[Edited on 14/2/09 by j-k]
posted on 14/2/09 at 10:34 AM Reply With Quote
Something like this?
Phil
[img][/img]
j-k
posted on 14/2/09 at 11:25 AM Reply With Quote
yep, thats pretty much what im after...
Did you buy that or make it youself?
What sort of price?
many thanks
jon
YQUSTA
posted on 14/2/09 at 02:07 PM Reply With Quote
I made mine from scratch.
They use the fixing screws for the shroud.
YQUSTA
j-k
posted on 14/2/09 at 03:13 PM Reply With Quote
i have already made a mockup plate for under the steering column, very similar to the above picture.
Have you got anymore photos of how you attach the paddle to the plate and what you have done to attach the gear change mechanism?
many thanks
jon
YQUSTA
posted on 14/2/09 at 05:42 PM Reply With Quote
These are the best images I have.
You just need 2 rod ends for the paddles.
Mine are M8 I think but they are going to get changed to M6 because the paddles are too close to the steering wheel.
In the image showing the cable connection, the rod end needs to be turned 90 degrees other wise it wont work properly.
j-k
posted on 14/2/09 at 05:56 PM Reply With Quote
many thanks....will give it a go then..
Is the thickness of the paddle about 5-6mm?
many thanks again
jon
YQUSTA
posted on 16/2/09 at 11:10 AM Reply With Quote
6mm
iiyama
posted on 16/2/09 at 06:16 PM Reply With Quote
Sierra column and switch gear, (although the plastic stalk has been replaced)
If its broke, fix it. If it aint broke, take it apart and find out how it works!
