| posted on 19/2/09 at 10:37 PM |
Alternative diff choices?
I've been pondering that perenial question of alternative diff choices.
Audi have made quattro 4wd cars for many years - would the rear diffs be useable?
I'm guessing the ratios may not be right, but they should be OK power/torque wise.
liam.mccaffrey
| posted on 19/2/09 at 10:38 PM |
im sure lsdweb is using a subaru diff
I have used a mx5 diff
[Edited on 19/2/09 by liam.mccaffrey]
Build Blog
Build Photo Album
| posted on 19/2/09 at 10:48 PM |
Reading a bit on VAG 4wd systems it appears cars with transverse engined 4wd systems have a non permanent "Haldex" drive system which uses
a clutch to engage RWD only when the FWD starts to slip/slide.
Maybe that rules out theses diffs?
What about the larger/longitudinal engined 4wd VAG cars?
greggors84
| posted on 19/2/09 at 11:35 PM |
Freelander diffs are becoming common in newer kits as the sierra ones become older.
I cant see the sierra ones becoming scarce anytime soon but eventually people will need to look else where.
BMW 3 series?
MX5?
[Edited on 19/2/2009 by greggors84]
Chris
The Magnificent 7!
Simon
| posted on 20/2/09 at 12:27 AM |
I have a 2.28:1 BMW diff (from 330D) that may eventually find its way into my car. It's heavier than the Sierra unit, but lighter than the Jag
IRS I was going to use.
There are dozens of ratios available.
Simon
matt_claydon
| posted on 20/2/09 at 08:23 AM |
I would have thought BMW would be the easiest option in terms of choice and availability in scrappies / on eBay.
Whatever you use there will be issues making driveshafts to fit if you stick with Sierra rear uprights though.
fazerruss
| posted on 20/2/09 at 11:54 AM |
I always wondered why the front wheels seem to slip when i dump the clutch on my octavia 4x4.
"if assholes could fly this place would be an airport"
