Author: Subject: another first drive
jamrogers
posted on 4/3/09 at 07:42 PM Reply With Quote
another first drive
I finally got my tax disk and numberplate authorisation form yesterday, got a q plate made up and put on the car, then got a whole 13 miles before cracking the sump on a manhole cover. pictures on my website below
build diary http://jamstigeravon.blogspot.com/
YouTube
https://youtu.be/JwwwilUd5Zo
UncleFista
posted on 4/3/09 at 07:46 PM Reply With Quote
Hope you switched off in time ;(
It's worth it in the end, honestly !
Tony Bond / UncleFista
locoR1
posted on 4/3/09 at 07:48 PM Reply With Quote
Bugger that's bad luck! looks like you did a proper job on the sump that's a big hole, did you notice in time to save the engine?
Check out my CB500T Cafe Racer build diary
Pdlewis
posted on 4/3/09 at 07:49 PM Reply With Quote
get in touch with the council surely the manhole shouldnt be that high!! there must be room for some compensation
Build Photo Album
Updated 05/02/2009
jamrogers
posted on 4/3/09 at 07:55 PM Reply With Quote
I cut the engine after a few seconds and rolled to a stop, so the engine should be fine, and i would contact the council for compensation but i don't want the blame for the trail of oil i left allong the road
YouTube
speedyxjs
posted on 4/3/09 at 07:57 PM Reply With Quote
Thats is a big hole. Hopefully you'll be back otr soon
mark chandler
posted on 4/3/09 at 08:04 PM Reply With Quote
While its in bits put in some baffles as wellImage deleted by owner
andrew-theasby
posted on 4/3/09 at 08:22 PM Reply With Quote
Unlucky, Great website btw, always nice to find a new build diary to browse through
jamrogers
posted on 4/3/09 at 08:29 PM Reply With Quote
I was thinking about bafels, but was going to see if i needed them first. Any thoughts people?
YouTube
mark chandler
posted on 4/3/09 at 08:46 PM Reply With Quote
You know you needed them after you have knocked out the big ends!
20 minutes cutting the material, it should not cost any more to get welded in so no argument really.
In the whole scheme of things given the time you have spent building the car this is just a faction of time and money.
Regards Mark
MakeEverything
posted on 4/3/09 at 09:24 PM Reply With Quote
Is that you with the file? You look like whatsisface from Catchphrase!!
Kindest Regards,
Richard.
andrew.carwithen
posted on 4/3/09 at 09:27 PM Reply With Quote
bloody hell!
That's bad luck and just isn't fair to have it happen on your maiden drive!
Did you get any photos of the offending manhole? (for evidence purposes)
Surely you'll be entitled to some form of compensation from the council for this?
What ground clearance did you have below the sump?
jamrogers
posted on 4/3/09 at 09:28 PM Reply With Quote
ha, no its my dad, i'll tell him u said that, its the first job i trusted him to do, and i took the file back after about 30 seconds - it was quicker to do it myself !!!
YouTube
posted on 4/3/09 at 09:39 PM Reply With Quote
Nice build blog there, surprised to see you needed a cat for a March 94 engine? Mine was a Feb 94 (no cat) and I was under the impression August 95 was the cutoff date..
jamrogers
posted on 4/3/09 at 09:42 PM Reply With Quote
I think i could have just passed withought it but after the first fail i just wanted to get through the test. I'm sure it will fall off at some point, a lot of the trim on the front suspension has already.
YouTube
jamrogers
posted on 5/3/09 at 10:31 AM Reply With Quote
incidentally he tested mine as a ford zetec engine which was in his database and so was virtually the same as a bet test (i think there was a bit of a wider limit for lambda) he wouldn't give me a non cat test as he had a match in the database for the engine. Follow the emissions diagram in the sva book and it'll make sense
YouTube
jamrogers
posted on 6/3/09 at 08:24 AM Reply With Quote
[Edited on 6/3/09 by jamrogers]
YouTube
jamrogers
My dad just sent me this..... He's a funny man isn't he. Rescued attachment Low Sump.JPG
YouTube
