Author: Subject: Designing a fuel tank
rumplitter
posted on 10/3/09 at 08:05 AM Reply With Quote
I had originally planned to use a plastic fuel cell.
I think I will now go down the road of having an aluminium tank made to fit exactly.
My original fuel cell had an inlet and outlet for fuel at the bottom of the tank and a breather at the top.
I intend to stick to this principle as I will have an external fuel pump. ETB sell a VDO Dip-Pipe Fuel Level Sensor which I like the look of.
I've attached a couple of pic's of what I intend to do, can I please have your opinions!
Regards
http://www.locostbuilders.co.uk/upload/MiniMojoProject.JPG
Mr Whippy
posted on 10/3/09 at 08:16 AM Reply With Quote
well at least its not going to be effected much by going round corners looks fine
designer
posted on 10/3/09 at 08:48 AM Reply With Quote
It's a very good idea, but, the question you have to ask yourself is.
Will it be worth the effort?
rumplitter
posted on 10/3/09 at 08:51 AM Reply With Quote
i've put a lot of effort time and money into everything else. My car isn't exactly low cost so i don't want to skimp on design at this stage, so little to complete before i strip the chassis and finally get it shot-blasted and powder-coated.
l0rd
posted on 10/3/09 at 09:13 AM Reply With Quote
My only concern is that you have way too many bends.
A lot more spots that can go wrong.
Can't you just make it straight like a 7 tank?
hellbent345
posted on 10/3/09 at 09:22 AM Reply With Quote
looks good to me, just the fabrication issues mentioned above, but that should be fine if you get it done by a professional, or if you yourself are a dab hand at the old tig welder!
one thing that could be interesting is the fuel level will not be very accurate with the level at the top being more than at the bottom if you know what i mean, but i dont think it should be too much of a problem.
Have you got a link to this fuel sender youve found, im interested in getting a dip stick sender also!
rumplitter
posted on 10/3/09 at 09:47 AM Reply With Quote
http://www.etbinstruments.com/Sensors_ancillaries_DD2.htm
Mr Whippy
posted on 10/3/09 at 11:41 AM Reply With Quote
you should try a horizontal cylindrical tank for scary readings
