New Topic New Reply
Author: Subject: Indy Full Cage
whitestu
posted on 17/3/09 at 04:46 PM Reply With Quote
Indy Full Cage
Anyone got any suggestions for full roll cage suppliers for an Indy [I'll be calling MK as well].
It's just for road use, so no need to comply with any racing regs.
Stu
bob tatt
posted on 17/3/09 at 05:06 PM Reply With Quote
mk fit mine and its superb think it was six hundred fitted although you have to remove the rear tub and tank to have it done.
oldtimer
posted on 17/3/09 at 05:39 PM Reply With Quote
Try Caged - I was very impressed when I visited them. 01373 452866. NTDWM either.
rb968
posted on 17/3/09 at 07:27 PM Reply With Quote
Don't know if Mark at MNR will fit his cage to other cars but always quite liked it. Slimmer tubes to the MK one it appears.
MNR cage
MNR cage
Rich
PAUL FISHER
posted on 17/3/09 at 09:01 PM Reply With Quote
The good thing with the MK supplied cage,is they will sell you one flat packed,so you can fit it yourself,or have it fitted locally
whitestu
posted on 19/3/09 at 09:22 PM Reply With Quote
How much is the flat packed cage from MK?
Stu
eccsmk
posted on 19/3/09 at 11:02 PM Reply With Quote
i asked this the other week and was told by then £450
C10CoryM
posted on 20/3/09 at 12:20 AM Reply With Quote
How come you want a full cage for the street only? The side and front of the halo, and any diagonals in it (as pictured) are very likely to make a mess out of your head in a hard crash. They are safer in races because you have a helmet, neck restraint and tight belts.
You may do better to have a good rollbar, knee bar and some side tubes for side impact.
Cheers.
"Our watchword evermore shall be: The Maple Leaf Forever!"
whitestu
posted on 20/3/09 at 02:35 PM Reply With Quote
Good question. Was really considering it for the safety aspect. I generally wear a helmet anyway.
Stu
Kriss
posted on 20/3/09 at 02:52 PM Reply With Quote
I wouldnt mind looking into a full cage this season depending how far I want to take things. Very happy with the car at the moment though.
Out of intrest, has anyone done an "outside mounted" cage on a indy. IE a cage that means the front bars do not go into the car against the dash but mount on the outside.
New Topic New Reply
