Author: Subject: Damn Speedo Magnet
thegasmen
posted on 21/3/09 at 06:20 PM Reply With Quote
Damn Speedo Magnet
I am Having Problems Glueing my speedo magnet on to the prop flange it just seems to come off all the time its fine untill i cane it then it just gives way ive used a new tub of superglue twice and also tried wurth twice any one have any ideas .what has everyone else used
Regards Mick
posted on 21/3/09 at 06:22 PM Reply With Quote
I used a rough file to key a little flat on the uj then Arildited the bugger on.
Still stuck fast after 1200 miles....
prawnabie
posted on 21/3/09 at 06:23 PM Reply With Quote
I had the same problem with araldite - I used that metal epoxy that looks like araldite at it has held so far for about 200 miles
Paul TigerB6
posted on 21/3/09 at 06:46 PM Reply With Quote
Did you drill into the flange in order to recess the magnet a bit. Done this with one recently and it got araldited in solidly (and got a coating of glue over the top of the magent also. I recon a nuclear expolsion wouldnt shift that little bugger now!!
mr henderson
posted on 21/3/09 at 06:49 PM Reply With Quote
But it might de-magnetise it!
roadrunner
posted on 21/3/09 at 06:51 PM Reply With Quote
Araldite has worked fine for me too.
westf27
posted on 21/3/09 at 06:54 PM Reply With Quote
we could try that if you like
555
Jon Ison
posted on 21/3/09 at 07:09 PM Reply With Quote
Drilled a small home for mine too, 13k still on there.
Paul TigerB6
posted on 21/3/09 at 07:19 PM Reply With Quote
Aralditing over the top? It stuck to the sensor pretty well still, and is giving a signal pushing the car about on the drive so seems fine. Not sure how its meant to de-magnetise a magnet really.
Jasper
posted on 21/3/09 at 07:28 PM Reply With Quote
Yup - another vote for Araldite, and a smear over the top, 2000 miles no probs.... and stuck it straight to the paint on the prop.
thegasmen
posted on 21/3/09 at 07:41 PM Reply With Quote
magnet issues
Thanks fellas
Ill get me self down to b and q tommorow and get some araldite 2 pack epoxy
I thought of drilling it but im fitting it on the edge of the prop adapter flange so its a bit tough.
mr henderson
posted on 21/3/09 at 08:23 PM Reply With Quote
Oh dear. Not the araldite, the nuclear explosion!!!!!
http://en.wikipedia.org/wiki/Electromagnetic_pulse
Paul TigerB6
posted on 21/3/09 at 08:51 PM Reply With Quote
Your humour has been wasted on me there Mr H!!
Thinking about it - thats the 2nd time i'll have nuked Richard Quinn's car in 2 weeks!!
1st time!!
posted on 21/3/09 at 10:42 PM Reply With Quote
Managed to get my sensor to pick up on the propshaft bolts , if you try this make sure the bolt heads are all in the same position or it cause a speedo fluctuation.
RoadkillUK
posted on 21/3/09 at 11:15 PM Reply With Quote
B&Q's own 'araldite' is good enough.
Roadkill - Lee
www.bradford7.co.uk
Latest Picture (14 Sept 2014)
LBMEFM
posted on 22/3/09 at 06:45 AM Reply With Quote
To add extra strength I have put small cable ties around each end of the magnet and glued them in too.
