FASTdan
posted on 26/3/09 at 09:11 AM |
fly screen - problem?
In my SVA lookover post a couple of people pointed out the flyscreen may be an issue regarding radius - so we've rounded the edges. However
reading other posts everyone seems to recommend removing screens for the test - are we going to have an issue with ours (maybe demisting/wipers etc?)
if we leave it on?
I'd take it off straight away except my mirror is suctioned onto it which would mean making a mount to come off the scuttle - not got that much
time to SVA given the other stuff still left to do.
![](http://img.photobucket.com/albums/0703/FASTdan/PA070273.jpg)
Steve Hignett
posted on 26/3/09 at 09:18 AM |
You can mount that type of mirror to the scuttle or the dash for the SVA, don't worry about it.
The rounded off of the edges is a fair point, but it's also a "field of view" issue, that's why it's just easier to
remove it.
adithorp
posted on 26/3/09 at 09:32 AM |
I'd remove it.
adrian
http://jpsc.org.uk/forum/
wilkingj
posted on 26/3/09 at 09:33 AM |
remove it.
Where ever you fit the mirror, make sure you can see all the marks on the ground as per the SVA manual. Look in my Archive under Mirrors. All the
marking out is in there.
I failed on Mirrors... Thats how I know
You only need washers, wipers, heater, if its tall enough to be deemed a windscreen.
They fit a jig on your seat, and the angles etc all dictate if its a windscreen or not.
So it can depend on your seat height on whether its a windscreen or not!
Best is to remove it completely, oe ensure it meets a flyscreen spec. Do a search on here, its all been explained before and with the diagrams for the
SVA jig thing.
I used the SVA approved mirror from either SVC or Europa... cant remember which.
Best Regards
Geoff
http://www.v8viento.co.uk
Schrodinger
posted on 26/3/09 at 03:38 PM |
IIRC you can't use a suction type mirror
Keith
Aviemore
foes
posted on 26/3/09 at 04:27 PM |
Mine passed fine with one, again it probably depends on the examiner on the day...
![](/images//smilies/smile.gif)
