gregs
posted on 3/4/09 at 05:14 PM |
my cr@p day at the RR
Really not a happy bunny Took my car down to RR today @ Mech to get properly setup, should have known it was going to go bad from the start when
the trailer slid down the drive into the garage door.....
Dave at Mech was fantastic but still human, problems we had:
1. ITBs would not balance , after adjusting screws for 1/2 an hour, cylinder 4 pulling all the air - finally identified that THE BUTTERFLY WAS
BENT!!!! fully shut, butterfly was clear at the top by about 1mm. No option but to bend it back (i have never heard of this before, and Dave had never
experienced it before..) bent back Dave was able to balance them. (any body got a single Gsxr 600 throttle body?)
2. Plugs fouling - car was not running sweet - I had put this down previously to my inability to map, but pulling the plugs 2&3 soaked in
oil.... new set, signs of oil after 15mins. Called it a day at this point.
Positive points - for the areas of the map we did look at, fuelling was about right. Maybe my mapping isn't as bad as I first
thought....
Where do I go from here? - cylinder head was refurbed & ported over the winter so unless I have been really unlucky with 2 stem seals
failing in no time? block was 2nd hand out of a westfield, re bored and only removed coz the guy upgraded to redtop, is possible the rings are shot,
but compression (throttle closed) was @ 150, 150, 142, 135, which suggests rings are ok?
Any guidance on how to determine where the oil is coming from appreciated, or where I should go from here - I am sort of tempted to pull the lump and
ask the guy who did the head to sort it for me.
Plan for the weekend - drop fluids & take off the inlet manifold, look at the back of the valves for oil.
Ho hum.
Greg
andyharding
posted on 3/4/09 at 05:19 PM |
I had 3 valve stem oils seals fail within a month or 2 of rebuilding my head. The seals were bought new but suspect they may have been old stock at
the motor factors. It's possible to replace the seals without removing the head. Solved my oil on plug problems.
gregs
posted on 3/4/09 at 05:21 PM |
cheers Andy - how did you change them, with the 'rope trick' or with a 'real' tool (compressor?)
mangogrooveworkshop
posted on 3/4/09 at 06:24 PM |
Use the rope trick first.....saves a new cylinder head gasket
gregs
posted on 3/4/09 at 06:27 PM |
have removed the manifold and there doesn't seem to be much on the back of the valves so not sure it's the stem seals- looks like it might
be the rings
chris-p-duck
posted on 3/4/09 at 06:46 PM |
I understand the text now........................
Hopefully tomorrow will be better
omega 24 v6
posted on 3/4/09 at 07:09 PM |
OH YES look for some of my efi posts. One of mine bent I Ireckoned it was when i had a backfire. It would only run on 3 cyls as it was WAY to lean.
twybrow
posted on 3/4/09 at 08:54 PM |
Strangely, I went to Mech Repairs today to talk about a RR session, and Dave mentioned he had just had a nightmare Pinto in with problems.... I feel
for you. It must be very frustrating!
Overall (I know it wasn't the session you had hoped for) how did you find Dave and Mech Repairs?
gregs
posted on 4/4/09 at 07:01 AM |
Dave is very laid back, but certainly knows his stuff, even with my sick engine, I could feel the difference he had made - I will be taking it back to
him once repaired.
C10CoryM
posted on 4/4/09 at 02:11 PM |
If the engine sat around for a long time and you don't have many miles on it you may have a couple stuck rings.
If so, try tipping a small amount of oil in each cylinder and going for a hard run as if you were trying to break in a new engine.
I had an oil burning truck that I thought the engine was done for so I got mad and ran the snot out of the it... turns out that's all it needed
to re-seal the rings and stop smoking.
Good Luck.
"Our watchword evermore shall be: The Maple Leaf Forever!"
gregs
posted on 4/4/09 at 08:24 PM |
haha! - took the head off this evening, and what do you know, valve stem seal moving up and down with the valve on cyl 2... have pushed it back into
position with a couple of lollipop sticks - do you think it is likely to pop off again, or should I replace it while the head is off?
Have looked at the bores and nothing looks odd, so am hoping the stem seal is the only issue...(backed up by yesterday's comp test) will get a
new gasket set & bolts in the morning and go from there.
Have started new thread on this
[Edited on 4/4/09 by gregs]
