Author: Subject: Megasquirt n spark - which coil?
novacaine
posted on 15/4/09 at 02:08 PM Reply With Quote
I've just finished building my Megasquirt V3 and now i need to sort out the ignition,
I was planning on running wasted spark with two coils as per This Page
What ignition coils should I use?
Im planning on putting the MS to use on a Zetec if that makes any difference...
as always, any help much appreciated
And you run and you run to catch up with the sun but its sinking, Racing around to come up behind you again, the sun is the same in a relative way but your older, shorter of breath and one day closer to death
omega0684
posted on 15/4/09 at 02:36 PM Reply With Quote
if you want to run wasted spark why dont you jsut run edis? then you can use a std coil pack
novacaine
posted on 15/4/09 at 03:03 PM Reply With Quote
I will look into that, my first impressions was that an independant wasted spark system would be easier but i'll have a look into edis now
Danozeman
posted on 15/4/09 at 03:37 PM Reply With Quote
Can you not put coil drivers on the megasquirt and use the standard zetec coil?
I must admit i dont know alot about it but im sure iv seen megasquirts with coil drivers to run them.
[Edited on 15/4/09 by Danozeman]
Dan
t16turbotone
posted on 15/4/09 at 04:46 PM Reply With Quote
^^^^yes with a v3 i think your right, you can connect the standard zetec coil pack directly to megasquirt no need for edis, if its v2.2 you will require edis
