Author: Subject: Welding mild steel to stainless?
mr henderson
posted on 19/4/09 at 09:02 PM Reply With Quote
Anyone done this, is it feasible?
I realise it's not desirable, but it may be necessary
John
big_wasa
posted on 19/4/09 at 09:06 PM Reply With Quote
Yep no probs.
Most budget exhausts are done this way. Mine has a mild steel flange with stainless tube welded up with mild wire.
Antnicuk
it can be done, what type of welder are you using? arc will be the strongest and you can get a special type of rod that will do it but i cant remember what they are called.
Best thing to do before welding 2 different types of material is to heat both before welding, when i have welded to cast turbo housings i have put both parts in the over for half an hour.
600 BHP per ton, Stylus Brought back from the dead! Turbo Rotary Powered!
posted on 19/4/09 at 09:13 PM Reply With Quote
Do you use stainless filler or mild?
madteg
posted on 19/4/09 at 09:15 PM Reply With Quote
DISSIMILAR RODS OR WIRE
mr henderson
posted on 19/4/09 at 09:24 PM Reply With Quote
Mig
Unfortunately it will not be practical to put the stainless steel in an oven (it's quite a big piece (think Robin Hood )
John
[Edited on 19/4/09 by mr henderson]
posted on 19/4/09 at 09:42 PM Reply With Quote
A lot depends on what you mean by stainless steel.
Stainless isn't one type of steel it is hundreds with very different compositions. -- some low grade stainless irons (the stuff kitchen sinks are made from) you can do a satisfactory low strength weld to mild steel but with true stainless steels you will get a very brittle weld if they do form weld at all.
Maradona
posted on 19/4/09 at 09:52 PM Reply With Quote
I do in mine and have no problems!
Diego,
The locost builder from Argentina
907
posted on 19/4/09 at 09:58 PM Reply With Quote
309 John
(see U2U)
Paul G
Mr Whippy
posted on 20/4/09 at 07:28 AM Reply With Quote
I've been using stainless repair patches for years doing up old cars. Apart from a few more sparks there's zero difference or problems in using it. No need to change anything.
