Cheffy
| posted on 19/4/09 at 10:36 PM |
This weekends efforts - new scuttle made!
Having spent some time wondering whether to make my own scuttle or just buy one I decided to sort of compromise. I had the materials so decided to
have a go at making one. If it came out half decent I'd go with that. Conversely, if it was a complete pile of poo I'd just bin it and buy a
fibreglass one.
It's taken two full days at 8 hours+ each day but I think it's actually come out really good. Although to be honest a fair chunk of the time
was spent bending and then unbending bits of metal to get the correct profile! Worth it in the end though I think - plus saved a few quid for a ready
made scuttle.
  Scuttle 1 small
  Scuttle 4 small
  Scuttle 12 small
  Scuttle 21 small
  Scuttle 25 small
Bit of trimming and fettling left to do but so far so good, then start on the dash!
Mart.
Farts are like Rock'n'Roll. You love your own but you hate everybody else's. Lemmy, Motorhead.
907
| posted on 20/4/09 at 05:20 AM |
That looks really good mate. Ace.
I do however have one tiny criticism......
Wrought iron chassis stands are a tad overkill.
Paul G
Mr Whippy
| posted on 20/4/09 at 06:30 AM |
like it
| posted on 20/4/09 at 09:19 AM |
Nice work - bet you wnet to bed a contented man on Sunday night
Daddylonglegs
| posted on 20/4/09 at 10:20 AM |
Nice job
What did you use to make it? I've got some sheets of thin ally lying around and want to make my own too.
JB
Cheffy
| posted on 20/4/09 at 04:20 PM |
Hi Guys,
Thanks for the comments.
Paul G - you're not the first to comment on the elaborate chassis stands Base unit from an old chilled catering display unit!
JB - I used some 3.3mm ali for the bulkhead panel first. Shaped that to the profile I wanted to match up with the bonnet line from the nose cone using
cardboard templates. Then I bent some 25mm x 3mm mild steel bar to match that profile, welded 9 tabs onto it and riveted the ali to the steel bar -
picture 1 in the original post.
Then I ground the ali back by about 8mm and bent another strip of steel bar (15mm x 3mm) to match that and tag welded that to the tabs on the first
piece. This will be the lip that the bonnet sits on - picture 2 in the original post and below. I also drilled the rivets back out and replaced them
with M5 Rivnuts.
  Scuttle 14 small
Next I re-profiled the rear hoop by making a hardboard template first and then just bending the tube to match the template little bit at a time using
a pipe bender I borrowed off a plumber mate - picture 3 in the original post.
Then I made a template for the skin out of some old lino - below:-
  Scuttle 16 small
And transfered this to some 1.6mm ali. Then it was just a question of measuring and paring away the excess and bending around the base of the scuttle
using a couple of ratchett straps to help hold things in place - pictures 4&5 in the original post.
Finally, I intend to fold the skin over the lip at the front (bonnet side) of the scuttle to meet the bonnet support lip. (If that makes sense!) Once
the bonnet support lip has a strip of rubber over it and with the bonnet in place I'm hoping I can get the bend tidy enough to look nice and
smooth. Something like the quality CAD picture below The white line is where the ali skin will fold over and then the black bit is obviously where
the rubber seal will sit.
  Scuttle sketch
Hope that makes sense and is of some use!
Mart.
Daddylonglegs
| posted on 20/4/09 at 08:18 PM |
Blimey! Now that's what I call a helpful answer
Cheers Mart.
JB
Cheffy
| posted on 20/4/09 at 09:57 PM |
Cheers Mart.
JB
My pleasure fella.
As a chef with no engineering skills whatsoever I take an awful lot out of this site and it's nice to be able to put something back!
(If that doesn't sound too nauseous!)
Mart.
RK
| posted on 21/4/09 at 02:08 AM |
Nice job. You should be chuffed about that. I thought of it and bought one - two actually, the first had problems.
