aaron bassett
| posted on 20/4/09 at 01:01 PM |
sierra diesel donor
i have a sierra diesel for sale non runner but every thing else is good cam belt has broke. £150 ono low millage 76000 diff ideal for BEC
| posted on 20/4/09 at 01:15 PM |
I'll give you £100 for the diff if its a 3.38.
Hows that sound?
hobzy
| posted on 20/4/09 at 01:19 PM |
Fight you for it
If its a 3.38 and coozer doesnt have it I'll have second dibs!
mcerd1
| posted on 20/4/09 at 01:38 PM |
but if its a 1.8D then it'll probably only have a 3.62
aaron bassett
| posted on 20/4/09 at 02:14 PM |
how can i tell without taking casing off
aaron bassett
| posted on 20/4/09 at 02:18 PM |
it is a turbo diesel
| posted on 20/4/09 at 02:37 PM |
There should be a tag with numbers stamped on it through one of the back cover bolts. Can you see it?
aaron bassett
| posted on 20/4/09 at 02:49 PM |
i will look tommorrow bit rushed atm
aaron bassett
| posted on 20/4/09 at 02:53 PM |
also got tax till 07 09
mads
| posted on 20/4/09 at 05:41 PM |
and if it's a 3.14 then I'll have it please?!
We gain knowledge faster than we do wisdom!
Life is not a journey to the grave with the intention of arriving safely in a pretty and well-preserved body, but rather to skid in
sideways, thoroughly used, totally worn out and loudly proclaiming... "f*ck, what a trip!"
redscamp
| posted on 20/4/09 at 06:15 PM |
sorry to rain on your prade
if its got a cam belt - its a 1.8
if its got a turbo - its a 1.8
aaron bassett
| posted on 20/4/09 at 06:33 PM |
fair enough its still for sale
aaron bassett
mcerd1
| posted on 20/4/09 at 10:38 PM |
just to confirm the diff ratio - whats the axle code on the vin plate ?
aaron bassett
| posted on 21/4/09 at 02:27 PM |
vin plate says u
diff plate
8 3bg 1c 362
a 2d09 1 356
| posted on 21/4/09 at 02:29 PM |
3.62
aaron bassett
| posted on 21/4/09 at 02:39 PM |
you can still by it if you want lol
mcerd1
| posted on 22/4/09 at 08:05 AM |
its still a good donor for someone - all they need is an engine.....
it'll have a type 9 box
(with a long input shaft but the bellhousing is longer too - I think)
I guess it will also have rear drum brakes, with push-in drive shafts
aaron bassett
| posted on 22/4/09 at 11:40 AM |
it has m8
