livelee
posted on 23/4/09 at 03:29 PM |
Alloy bell housing for a type 9 gearbox.
I would like to buy one. Does anybody have one they would like to sell me?
Thanks.
Dan.
blakep82
posted on 23/4/09 at 03:30 PM |
which engine?
________________________
cd.thomson
posted on 23/4/09 at 03:33 PM |
I guess the standard ford bolt pattern
Craig
omega0684
posted on 23/4/09 at 03:36 PM |
you can pick them up on ebay occasionally but they go for anything between £90-£150
livelee
posted on 23/4/09 at 03:42 PM |
The gearbox is attached to a silvertop 2.0L Zetec. As I understand this is a standard bolt pattern. Are there multiple types of alloy housings with
different bolt patterns?
Dan
cd.thomson
posted on 23/4/09 at 03:44 PM |
yes there are, there are two for vauxhall redtop bolt pattern for example. These will be clearly marked though, so I wouldn't worry about buying
the wrong thing.
Craig
livelee
posted on 23/4/09 at 03:48 PM |
Thanks Craig
Mal
posted on 23/4/09 at 03:59 PM |
RS2000 Bellhousing
I have an RS2000 aluminium bellhousing to sell. It will couple a type 9 gearbox to a Zetec engine.
However it has prevoiusly had cracks poorly welded and needs this work rectifying.
£25, if its any good to you.
Mal
livelee
posted on 23/4/09 at 09:03 PM |
Thanks mal. does that have the double sided starter motor? if so it's not going to fit in my tunnel.
I need one with a starter on the right (as you look at the bell housing from the front (big open end))
Dan
posted on 23/4/09 at 09:21 PM |
I bought one and it doesn't fit, the car that is. Connects the zetec to the type 9 but was too wide for the tunnel.
The standard type 9 release arm doesn't fit and I don't know what does, never bothered to find out.
Its now going to get chopped up and made to fit a Toyota Supra box
Rally Design have them check THIS!
SaveTheDodo
posted on 27/4/09 at 12:37 PM |
You have U2U.......
Andrew
