Author: Subject: What size pop rivets do I need?
aerosam
posted on 23/4/09 at 07:13 PM Reply With Quote
I'll soon be fitting the ali panels to my chassis. (I just have to finish welding it, paint it, and cut the panels out first - maybe not that soon then!)
The floor is 2mm ali, the rest is 1.2mm ali, the chassis tubes are all the usual 1.6mm ERW tube.
So what are the ideal sizes of pop rivets i need for either thickness of panel?
Thanks!
Sam
Had enough of this dictatorship known as LCB. Gone elsewhere, not coming back. Kiss my ass ChrisW.
cjtheman
posted on 23/4/09 at 07:32 PM Reply With Quote
hi sam
i used 13/64 ( 5 mm )for the floor all blind
and 4mm for all the internal panels
cheers
colin
wanted
sunny weather
sva pass 12/6/09
taxed 16/6/09
Mal
posted on 23/4/09 at 07:36 PM Reply With Quote
4mm diameter x 10 long closed end, to prevent water ingress. The length could be a little shorter, but not less than 8mm.
Mal
Avoneer
posted on 23/4/09 at 09:16 PM Reply With Quote
I'd definately use 4.8's for the floor, but 3.2's are fine for everything else.
I've built 2 this way with no problems.
Bead all the chassis tubes with silicone or like to prevent vibration and water ingress.
Pat...
