cd.thomson
| posted on 25/4/09 at 11:44 AM |
remove type 9 bellhousing/clutch fork
How on earth do you get the bellhousing off the type 9 gearbox?
I've removed the two obvious bolts but now need to take the clutch fork and release bearing out to get at the other two. The problem is I dont
see any way of getting the fork off its stud, theres noway to get enough angle on it..
Dont make me angry grind it!
Craig
omega0684
| posted on 25/4/09 at 11:45 AM |
mate there is a small clip on the back of the trust bearing that you need to push in as you pull it off, then the arm should just come off
BE CAREFUL NOT TO BREAK THE CLIP THROUGH EXCESSIVE FORCE!
[Edited on 25/4/09 by omega0684]
cd.thomson
| posted on 25/4/09 at 11:51 AM |
done it, cheers
Craig
