Author: Subject: Fuel economy, or not
jollygreengiant
posted on 25/4/09 at 02:55 PM Reply With Quote
Well I was out for a drive today and my fuel guage said I was running on fumes. So being a good lad and having done some 300 miles since SVA I thought it was about time that I put some juice in. When the petol nozzle cut out at about only £25's worth I pulled it out and had a look. Then I finished filling and had it brimmed at £38's worth.
When I got home I put my fuel fill details into the spread sheet that I use to monitor fuel usage and running cost. I was quite dissapointed that it gave me an overall figure of 38mpg.
I obviously have not been giving enough of a blasting yet.
Oh for information Luego Viento, 2.0 injection Pinto (fast road injection cam) otherwise std. 3.38 diff with 195/45/15 toyo's.
Whats everyone else getting.???
theconrodkid
posted on 25/4/09 at 03:11 PM Reply With Quote
my zetec with injection only manages 20 ish,but then it is running like poo at the mo
who cares who wins
pass the pork pies
tegwin
posted on 25/4/09 at 03:19 PM Reply With Quote
38?.... quit ya jibba jabba.... the last time I filled the TVR it had only done 16MPG.... Its only a 2.5 litre 6Cyl..... must be something wrong with it! :p
www.verticalhorizonsmedia.tv
iscmatt
Contributor
Posts 1929
Registered 30/3/06
Location York
Member Is Offline
Photo Archive Go!
Building: - BUILT - 2.0 pinto indy, Kent Cam, zzr1100 carbs
posted on 25/4/09 at 03:54 PM Reply With Quote
I'm getting around 20- 25 mpg with my pinto (bike carbs).
i do around 120 miles or so a tank?
flak monkey
posted on 25/4/09 at 04:51 PM Reply With Quote
I now get around 30mpg from the pinto on gsxr 600 throttle bodies running around here, will see how it goes on the way to stoneleigh next week, expect it will be closer to 35.
Sera
http://www.motosera.com
ditchlewis
posted on 25/4/09 at 05:10 PM Reply With Quote
i have a 2.1 pinto with 45's and i have a range betweew 8Mpg and 25Mpg
when i get 8 i'm having fun when i get 25 Mpg it's on a motorway
ditch
posted on 25/4/09 at 05:31 PM Reply With Quote
Clive, you can't be getting full throttle!!
Mark Allanson
posted on 25/4/09 at 07:07 PM Reply With Quote
My pinto 2.0I gets upto 24mpg in 'normal' driving, but when I drive very gently it rises to 65mpg
Stuart_B
posted on 25/4/09 at 07:50 PM Reply With Quote
that is great. i wish i had that
clairetoo
posted on 25/4/09 at 07:54 PM Reply With Quote
My old crossflow (mad 165 brake spec ) used to do high 40`s on the motorway , and around fourty normal running (bike TB's and Omex)
If I can get 20 mpg from the V6 I am surprised - but unhappy - I'd rather be seeing double that
The cost of fuel is the only reason for it to be spending more time sitting on the drive than being used .
Its cuz I is blond , innit
Claire xx
Will weld for food......
Scotty
posted on 26/4/09 at 02:43 PM Reply With Quote
done some 900 miles in mine now, regular as clockwork - 20 mpg
PLEASE NOTE! All comments made by this person are to be considered "Tongue in Cheek" and are not meant to be taken seriously in any way - so there!
DIY Si
posted on 26/4/09 at 04:08 PM Reply With Quote
£15 of fuel gives me an indicated 100 miles. Which is actually 100 KM. So that's roughly 17.8 mpg. And that's an average. If I'm really trying I can get it down to 10 mpg.
Sun Tzu, The Art of War
Ninehigh
posted on 27/4/09 at 01:23 AM Reply With Quote
Is this just the most fun way to burn loads of petrol or what?
C10CoryM
posted on 29/4/09 at 12:56 AM Reply With Quote
I am curious to see what mpg I get with mine. The car the engine came from was capable of 30-35mpg on the freeway, but weighs more than double. I figure I will get better fuel economy than my daily driver, but the cost of premium fuel will make it about even. Makes it pretty easy to justify taking the fun car for a drive.
To put things in perspective, my last toy car was a 6.2L (377ci), camaro that got about 9mpg and barely ran on 94octane. I once burned 180L of fuel in one (fun!) night.
Other than at very high speeds, the locost should easily out-perform the camaro in: handling, acceleration, braking, drivability and hopefully reliability.
It shouldn't frag driveline parts on a regular basis like the camaro did at least
Cheers.
Cory
"Our watchword evermore shall be: The Maple Leaf Forever!"
