Author: Subject: slight clutch slip
thegasmen
posted on 26/4/09 at 08:24 PM Reply With Quote
slight clutch slip
Weird thing happened today had to do a 40 mile journey on motorway in my blackbird engined rush had the car at a steady speed but when i put foot down the car picked up in top gear but i heard the clutch slip the oil temparature had risen slightly it did this a couple of times but noticed when the temparature came down a bit it didnt slip at all i have noticed that the clutch biting point seems to move higher up the pedal the warmer the engine gets I am running an accusump with 1 litre overfill and standard bike oil cooler do you think i should add a bigger oil cooler or add another oil cooler to the system or do you think its something else
Regards Mick
thegasmen
posted on 26/4/09 at 09:21 PM Reply With Quote
clutch slip
Im using millers semi synthetic
posted on 26/4/09 at 10:43 PM Reply With Quote
Sounds like an overfill issue... drain some off and try it again.
