blakep82
posted on 1/5/09 at 03:04 PM |
spring 'poundage'
don't even know if poundage is a word... anyway, is the number normally stamped into the spring anywhere?
according to the pickup truck website they use 900lbs springs on the front (seems a lot!), and 225lbs on the back
I've never checked mine, but it never sits flat on the ground either, it always sits at a funny angle, especially when jacked up.
just hoping theres an easy way to check them
________________________
frodo_monkey
posted on 1/5/09 at 03:13 PM |
Whip the springs off - if you're lucky it will be written on the top/bottm or carved it. If not then you'll need a spring dyno (Procomp on
here has one).
"Racing is life. Anything before or after is just waiting."
blakep82
posted on 1/5/09 at 03:29 PM |
hopefully they're written on there then i thought they would always be stamped on or something.
the guy i got them from told me they were all 300lbs, but i'm not convinced
mr henderson
posted on 1/5/09 at 03:34 PM |
You don't need a spring dyno, all you need is a bathroom scales and some safe way of compressing the spring on it, and a way of measuring it
while you are doing that.
Measure the free length, then compress it by an inch if possible, or whatever you can, measure it in the compressed length.
If it was compressed 1/2 inch, and the scale reas 200lbs, then that would be a 400lb spring
John
I SAID A SAFE WAY OF COMPRESSING AND MEASURING IT!
matt_claydon
posted on 1/5/09 at 04:00 PM |
Pillar drill to compress and bathroom scales to measure force works well. Stick a 10mm bit or some round bar in the chuck too to stop the spring
flying out if it slips
philw
posted on 1/5/09 at 04:47 PM |
John
A fat lardy girlfriend should do it
Must try harder
MikeCapon
posted on 1/5/09 at 07:53 PM |
If you can hang on a bit I've a way of calculating a spring's rate by measuring it. Be tomorrow though?
MikeCapon
posted on 1/5/09 at 08:53 PM |
Here you go
