jpindy3
posted on 4/5/09 at 12:56 PM |
cossie 4x4 pistos rods
do these fit the pinto block,or dose it need boring out???
thanks
jamie
[Edited on 4/5/09 by jpindy3]
i have found some,thay would be good for my turbo build,
disco_biscuit
posted on 4/5/09 at 01:13 PM |
From what i remember if its a 205 block you should be fine,
phoenix70
posted on 4/5/09 at 02:13 PM |
You will need to bore out the engine to fit them, I think, but the 205 block will take the bore.
Rob Allison
posted on 6/5/09 at 01:00 AM |
Cossies run the same bore sizes as its the same block
You just need to know if they are over size. i.e. for a re-bore.
You would be best off with .5mm oversize. Then you can have the block bored/honed to fit the pistons.
There are loads of second hand standard pistons because they can not be fitted to a worn bore block.
