Author: Subject: bicycle spedo
Maradona
posted on 6/5/09 at 09:21 PM Reply With Quote
bicycle spedo
I have a bicycle spedometer cateye vectra cc 7000, I would know if I can cut the cable and add a 2 mts extension to put in the car,
The manufacturer say imposible, but I try in my mountainbike and work ok, i dont know waht happen if I add 2 mts of cable.
Diego,
The locost builder from Argentina
austin man
posted on 6/5/09 at 09:49 PM Reply With Quote
Cant see there would be a problem its still only counting the revolutions of the wheel can you not fix it to the front wheel to save you needing to extend the cable ??
clairetoo
posted on 6/5/09 at 09:53 PM Reply With Quote
The only problem I have encountered with extending the wire's on push-bike speedo's is that some of them have a sort of conductive `string` rather than proper copper wire , which is allmost impossible to solder
Other than that - it works fine
Its cuz I is blond , innit
Claire xx
Will weld for food......
posted on 7/5/09 at 12:30 AM Reply With Quote
That would be Fibre Optic Cable then which is typically unsolderabubble...
Staple balls
posted on 7/5/09 at 12:42 AM Reply With Quote
Possibly that weird nylon (I think) cored copper cable as used in cheap headphones?
Not impossible to solder, but not worth doing.
IME you're better off desoldering at both ends and replacing it with a twisted pair from some cat5 cable (which I often do with headphones, might well work with a bike speedo )
posted on 7/5/09 at 06:45 AM Reply With Quote
it is extremely possible - I have done this on mine = a Halfords bike speedo.
I cannot remember if I soldered the wires together - strip the insulation, twist wires together, blob of flux, apply heat and solder = job done - or used the small terminal blocks, probably the latter as the speedo was not meant to be a permanent feature.
posted on 7/5/09 at 07:42 AM Reply With Quote
It's "wire" in the sense that it's conductive, but not like traditional copper. The reason for it is that it's highly flexible and won't break under constant flexing like copper does.
