Author: Subject: Propshaft failure
Sprint Rich
posted on 7/5/09 at 12:30 AM Reply With Quote
Propshaft failure
Just suffered massive propshaft failure on a Dutton Malaga.
Question A; Whos best near the south coast for custom propshafts?
B: Fibreglass gel coat repairs, worth the money to do or just replace?
C: Underpant replacement?
posted on 7/5/09 at 12:31 AM Reply With Quote
Cant help with advice re the propshaft supplier but undercrackers.. figleaves are good, if a little expensive...
Worzey
posted on 7/5/09 at 06:41 AM Reply With Quote
Autoprop in Felbridge (East Grinstead) for the Prop Shaft.
Caterham R400
posted on 7/5/09 at 06:55 AM Reply With Quote
how did it fail, any photos?
40inches
posted on 7/5/09 at 07:31 AM Reply With Quote
There you go http://www.redlandhealthcare.co.uk/scripts/prodView.asp?idproduct=390
maartenromijn
posted on 7/5/09 at 10:27 AM Reply With Quote
I hope no personal injuries?
BLOG: http://thunderroad-super7.blogspot.com/
myke pocock
posted on 7/5/09 at 10:43 AM Reply With Quote
Regarding undercrackers, I wonder if the Army have carbon kevlar Y's. May get a second hand pair on ebay but could be a bit discoloured depending where they came from.
jimgiblett
posted on 7/5/09 at 10:44 AM Reply With Quote
Yep Autoprop vote from me. Strange plce but great service.
- Jim
hobzy
posted on 7/5/09 at 11:27 AM Reply With Quote
Rich were you on the a34 on monday? If yes then I went past and waved in my orange indy. Where did it happen?
iank
posted on 7/5/09 at 01:20 PM Reply With Quote
Depends how bad the fibreglass has been damaged and what the cost/availability of the replacement parts is like.
If the prop went through something then it's likely to be a pain to get looking good and being strong again, so a new panel is probably the answer.
Underpant replacement is probably required if the prop joined you in the passenger compartment. I think the bin-men would appreciate the old set being bagged and sealed
[Edited on 7/5/09 by iank]
Anonymous
Mr G
posted on 8/5/09 at 01:17 PM Reply With Quote
Piccys can be found HERE
Billys propshaft failure with pics (lucky I was'nt a passenger that day!) HERE
G
[Edited on 8/5/09 by Mr G]
C10CoryM
posted on 12/5/09 at 01:07 AM Reply With Quote
Driveshafts tend to break for only 3 reasons:
-overspeed. The slight unbalance gets worse and worse and WHAM! it tears itself apart.
-too much torque. Unlikely in your case.
-previous damage. A dent or bent shaft causing one of the above failures at lower speeds/torque.
I would suggest doing some math to see just how fast your driveshaft is spinning. If you have an overdrive transmission you may be overspeeding it at high speeds.
Cheers.
Cory
"Our watchword evermore shall be: The Maple Leaf Forever!"
Johneturbo
posted on 12/5/09 at 01:36 PM Reply With Quote
Cheers.
Cory
