New Topic New Reply
Author: Subject: cheep koso universal speedo digital
thunderace
posted on 13/5/09 at 08:30 AM Reply With Quote
Price: 122,50EUR
Speedo Koso XR-SR N - digital blue display.
Newly arrived KOSO universal speedo for vehicles with 2stroke or 4stroke engine, as well for carb as for injector engines.
The design of the display is a really proper affair. The blue lights makes the speedo reading an easy task both night and day!
The KOSO XR SR provides the sport drivers with all the required information: speed, temperature of some operating fluids, fuel level. Additionally to this there are some functions reserved to have it programmed to your requirements..
Here you will find the overview of the features:
Speed reading optional in km/h or mph
Speed readings up to 360 km/h (223 MPH)
km reading up to 0-99999km
Trip meter 0-999,9km
Rev counter up to 0-18000 RPM
Rev counter of the record mode up to 15000 RPM
Digital reading of water temperature up to 120° C (248° F)
Top temperature reading
Fuel level reading 100 Ohm /510 Ohm
Clock 24 H
Top Speed reading
Voltage 12 Volt
Lighting 12 Volt (blue)
Measurement 116.3x72.4x32.3 mm
Weight 286 g
Pilot lamps:
Neutral
Hi Beam
Light
Indicators
Oiltemperatures
Water temperature
Warning lights
The delivery contains the speedo, connection wire, sensor, magnets, brackets, and Fitting and Instruction Manual (English language).
http://scooter-center.com/catalog/product_info.php?products_id=10978&language=en&PHPSESSID=e98a34becdf83c5c4e361cc92f5fcd64
Omni
posted on 13/5/09 at 08:58 AM Reply With Quote
Looks good
Also check out the KOSO RS DYNO vid HERE
O
rgrs
posted on 13/5/09 at 09:12 AM Reply With Quote
They are reasonably good especially for the price but....... sva-iva FAIL,
If you press the bottom button, the screen stops displaying the current vehicle speed.. hence fail.
However mine is currently open on the bench undergoing modification, will post a fix later
Regards Roger
YQUSTA
posted on 13/5/09 at 10:09 AM Reply With Quote
I have 1 of these fitted and the display is good in the dark and light conditions.
The only problem is the fuel display because of the ohm rating but this can be over come by using a bike sender I believe the blackbird 1 is fine not sure which others.
This is a mod I need to do at some time.
The unit can also be split in 2 so it sits at a lower profile on the dash there is a pic in my archive of it split mounted to a carbon dash.
New Topic New Reply
