<<  1    2    3  >>
Author: Subject: Has anyone figured out a proper Locost reverse for IVA yet?
40inches
posted on 15/5/09 at 11:55 AM Reply With Quote
Originally posted by Hellfire
Sounds to me like there's a market here for a 'rent-a-reverse', in a similar way to the 'rent-a-cat' for IVA purposes.
I'm sure whoever designs and builds a simple one that could be easily transferred from vehicle to vehicle, would soon recoup their initial outlay and even make a few quid
Phil
Would there be any consequences from removing reverse after IVA? Someone mentioned not being insured if you did this
posted on 15/5/09 at 04:58 PM Reply With Quote
I wouldn't imagine that removing reverse after IVA would be an issue. Most BEC's don't have reverse and I'm not aware that insurance companies now state it must be a requirement.
Phil
tommyab
posted on 17/5/09 at 10:21 AM Reply With Quote
There are a lot of variables involved in fabricating an electric reverse, not least is using a starter motor that runs in the correct direction, if you don't want another forward gear
Then there is finding a starter with a gear pitch that can be replicated, some manufactures use some very strange pitch and pressure angles.
You then need a starter that is small enough to fit, but powerful enough to move the car and at least the driver.
So far I have found what I believe to be a suitable starter and have ordered a spur gear that will fit on the diff flange as per MK, also have just finished the drawings for a motor mount that can be either bolted, or welded on the chassis and is adjustable, so in theory it should fit most 7's.
All this lot should come together in about 2 weeks, so if you can wait I could put it all together with relays and wiring and try for a group buy, but I will definitely post a shopping list, if it all works
I'd be interested in a group buy as well. I was trying to figure out the gear myself, got the standard on gears which I can calc the teeth profiles from, but I cant find any info. on the profiles of starter motor teeth to use as the starting point.
Do you mind me asking what motor you are using and have you got the teeth profiles of it?
cheers.
Tom
40inches
posted on 17/5/09 at 03:23 PM Reply With Quote
I found the Golf Mk4 to be ok for size and power. As said, starter motor gear teeth are a bit on the strange side, so I found it easier to take a VAG ring gear to the gear manufactures and it came out as a 12DP. I was expecting a MOD pitch!
This won't be working and confirmed until I have the new spur gear back.
posted on 19/5/09 at 12:07 PM Reply With Quote
Could you get enough torque/grip from a starter motor to work some kind of reverse with a rubber wheel against the prop/diff. i.e. mount a rubber tyred wheel of some sort on the starter motor shaft and then mount the motor next to/above the diff on some sort of pivot arrangement so the rubber wheel can be lowered against the difff flange (might meed some sort of mating rubber section on the diff flange) to provide the drive. If the motor pivoted the right way, the rotation of the wheel would pull itself against the diff flange.
Simple and cheap to make and operate (lever next to handbrake maybe) and no power loss when it's not in use.
rb968
posted on 20/5/09 at 03:19 PM Reply With Quote
I picked up a Ford Fiesta 1.25 Zetec starter and sent that to HPC Gears yesterday. They have confirmed it is 12 DP and have quoted me £69 +VAT for a 131mm dia spur gear (10mm width).
Might be able to push the diameter a bit if you want to "expand" the tunnel sides but thats pretty close to the max space I see as available. Going to have a measure up tonight before I decide to order it.
Will keep you posted.
Rich
40inches
posted on 20/5/09 at 03:46 PM Reply With Quote
Rich
Are you able to machine the bores yourself? the price for a 60 tooth 12DP is £43, they charge £26 to skim the gear from it's standard 19mm width They also charge £17 for a bore up to 99mm and a further £35 for another bore over 100mm, all plus vat!
rb968
posted on 20/5/09 at 04:18 PM Reply With Quote
I work for an engineering firm so opening the bore from 22mm standard and drilling the holes for the prop/diff bolt pattern is not a problem for me. Just can't cut spur gears!
You need a friendly machine shop to finish the job!
Rich
rb968
posted on 20/5/09 at 04:21 PM Reply With Quote
Who is the chap on here with the water cutting machine. Can he help with the bore and holes?
Rich
rb968
posted on 20/5/09 at 10:03 PM Reply With Quote
After , measuring up tonight i think ineed to up the gear dia to 6" which takes it about 5mm into the cabin either side of the tunnel. Will get anew quote. Anyone know what size gear MK supply?
Rich
40inches
posted on 21/5/09 at 10:58 AM Reply With Quote
Rich
64 teeth, if 12DP, 5.5 inches
rb968
posted on 21/5/09 at 01:03 PM Reply With Quote
New quote for 6.0" PCD (6.167" OD) is £78.97.
They forgot to change number of teeth but am assuming 66 based on your post.
Reason for going bigger is I have sent the starter away and am now worrying there is not enough room for it under the prop at the smaller size and that I will blow £100 on a gear and the starter fouls the prop! I don;t want to be working to mm clearances when its spinning at that rate :-0
Will have to reinforce the tunnel side and bow out those sections to cover the gear as per the MK version. Not great but hey needs must.
Rich
40inches
posted on 21/5/09 at 02:11 PM Reply With Quote
Rich
You may have to modify top of starter as per drawing to stop prop fouling.
Check photos in this thread to see how MK have had to hack the starter for clearance.
http://locostbuilders.co.uk/viewthread.php?tid=110570
VAG starter
VAG starter
peteday_uk@btinternet.com
posted on 21/5/09 at 07:11 PM Reply With Quote
I noticed at Stoneleigh that MK are now mounting their starter motor from the top rails so they have no need to cut the floor.
They are using a VW starter motor.
&#65532;&#65532; (was trying to insert an image, but don't know how).
&#65532;
&#65532;&#65532;
Pete.
[Edited on 21/5/09 by peteday_uk@btinternet.com]
rb968
posted on 22/5/09 at 08:40 AM Reply With Quote
I looked at that but the handbrake mechanism seemed to be in the way.
The photos of the MK setup were useful as you say they showed you would probably need to grid away the top part of the alloy housing. The Fiesta starter has a 4 mm approx lip which will need removing.
Rich
rb968
posted on 22/5/09 at 11:03 AM Reply With Quote
Have ordered the bugger now so fingers crossed ! 72 teeth 6" PCD 12 DP.
Rich
40inches
posted on 22/5/09 at 12:20 PM Reply With Quote
Have you paid yet? went down to HPC yesterday to see if mine was ready, not started it yet apparently was on pro former invoice, however they forgot to send it to me, or even tell me No apology, just that they will do their best to get it out next week???? NOT impressed!
rb968
posted on 22/5/09 at 03:19 PM Reply With Quote
Yep paid and the nice lady said up to 14 days.
Will wait and see ! Hope you get yours sorted.
Rich
Ninehigh
posted on 22/5/09 at 08:18 PM Reply With Quote
Originally posted by nick205
How about keeping a wooden pole behind your seat?
When you need to reverse you simply use the pole to "punt" yourself backwards. No need to even undo your harness. Should be easy what with you BEC boys being so low weight of course
Why not cut a door into the floor and have a flintstones style reverse? Seeing as they're so light, and surely a hinge and a bolt is less weight than even a carbon fibre pole
tommyab
posted on 27/5/09 at 07:14 PM Reply With Quote
This might be a silly question but why does the gear need to be bored out to such an extent? Would a circular plate with teeth cut and holes drilled not do the job?
40inches
posted on 28/5/09 at 12:37 PM Reply With Quote
The prop needs to be located firmly on the diff by a spigot, the large bore fits over the diff flange and the prop spigots into the small diameter bore.
Relying on the 4 bolts holding the prop to the diff flange don't think so! plus the gear needs to run true.
Picked mine up this morning, just finished drilling holes and chemically blacking it
tommyab
posted on 28/5/09 at 06:25 PM Reply With Quote
Hehe. Fair enough. I guess those bolts are quite small. Im not used to engineering stuff on such a small scale (offshore construction/installation is my day job).
Thats looking good. I am following you guys progress with much interest!
Tom
40inches
posted on 11/6/09 at 09:40 AM Reply With Quote
First test
Brackets in place and adjusted.
Have put a video on YouTube http://www.youtube.com/watch?v=a0V0clui0BQ
posted on 11/6/09 at 11:47 AM Reply With Quote
I have just looked at the video. Looks good. I have to be honest and say in my own mind the reverse would be alot slower than that. Or is it simply a case of it not being connected to anything?
[Edited on 11/6/09 by peteday_uk@btinternet.com]
40inches
posted on 11/6/09 at 12:23 PM Reply With Quote
It's a lot slower at the wheels, perhaps walking pace, you have to factor in the diff ratio
<<  1    2    3  >>
