Author: Subject: Creaking Ford Ka
RichardK
posted on 29/5/09 at 10:25 PM Reply With Quote
Creaking Ford Ka
Wifes Ka has started creaking on the drivers side, did both wishbones last year so am sure its not those,I think it coming from the strut tops and I've heard that the strut top are prone to failure, how hard are they to fit?
As most bolts tend to shear off at the drop of a hat on this delightful little motor The car is a 2000 1.3 btw and the mot is due in July is this creaking a failure??
Rich
Gallery updated 11/01/2011
blakep82
posted on 29/5/09 at 10:26 PM Reply With Quote
creaking won't be a failure
________________________
Danozeman
posted on 29/5/09 at 10:32 PM Reply With Quote
Creaking wont be a failure.
They creak on the top strut bush. We solved my mates one for a bit with silicon lube.
Dan
sminney
posted on 29/5/09 at 10:47 PM Reply With Quote
as above creaking is ok, mine has done it for last few years... did the top strut isolators last mot, as there was play in the strut when it was jacked up, not a bad job as long as you have spring compressors and a big rubber mallet to get the bottom of the strut and the hub seperated! creaking still there after new rubbers put in, I presumed it was the roll bar bushes?
Regards
Steve Minney
MikeR
posted on 30/5/09 at 12:14 AM Reply With Quote
cousin used to do a simple test....
hose pipe under wheel arch for minute.
If it stopped creaking it was just dry bushes. If it didn't i needed looking at.
