Author: Subject: FS Mig Welder - Cebora MIG 140
r1_pete
posted on 7/6/09 at 09:38 AM Reply With Quote
Cebora MIG140.
Hose and regulator for large Argoshield.
Bag of Spare tips.
Spare Torch Shroud.
five KG Roll of .6mm wire.
five KG Roll of .8mm wire.
Auto darkening mask.
Obviously the Argo bottle belongs to BOC so isn't included, but will keep to enable any prospective buyer to try the unit.
Looking for £120 - which is not much more than the cost of the accessories and consumables.
omega0684
posted on 7/6/09 at 10:01 AM Reply With Quote
do you have any further info on the mig, im struggling to find anything on the net, how old is it, settings, amp rating etc?
[Edited on 7/6/09 by omega0684]
MikeR
I had a cebora 100 and it too loads of abuse. The welding shops also used to like them as they're pretty much an industrial unit. Who ever buys that should get a good welder.
r1_pete
posted on 7/6/09 at 10:11 AM Reply With Quote
Sure Omega,
Its about 4 years old, I've had it 2 years, was used in a bodyshop so has not had the long high power runs it is capable of, its fan cooled for constant use.
4 power setting with infinately variable wire speed in each setting.
Here's a better pic of the front:
posted on 7/6/09 at 10:18 AM Reply With Quote
see 150 SIEGEN SEALEY MIG WELDER SO816 WELDING FREEPOST NEW Item number: 120427685939 for 190 GBP
(was looking at sealey before I fixed my wire feed motor).
flak monkey
posted on 7/6/09 at 10:38 AM Reply With Quote
OOo sorely tempted, but also skint
Sera
http://www.motosera.com
omega0684
posted on 7/6/09 at 10:39 AM Reply With Quote
sorry im struggling to read the photo
what are the lower and higher amp values?
Dangle_kt
posted on 7/6/09 at 01:03 PM Reply With Quote
for the money that isn't bad at all, I just paid a few quid more for a similar spec aldi welder.
I beleive cebora also rebranded for snap-on, which might yeald more info?
I have a 3 year warrenty, but I don't have a tried and tested unit that has available spare parts.
If it includes the regulator then its a bargain as they are about £30-40 depending on spec, the auto darken masks arn't cheap on their own either, and the large reels of wire make it a great deal IMO.
r1_pete
posted on 7/6/09 at 01:36 PM Reply With Quote
It doesn't specify the current at each setting, minimum is 30A at 15v, max is 140A at 19.5v.
The snap on range used these machines re-badged to snap on.
omega0684
posted on 7/6/09 at 06:06 PM Reply With Quote
u2u mate
