Author: Subject: Basic gasket question
Benzine
posted on 19/6/09 at 11:22 AM Reply With Quote
When fitting a new inlet manifold gasket, do you use some kind of liquid gasket alongside the actual gasket? Or just as it is? I have some hylomar aerosol, just wondering if it's worth using it alongside for extra air-tightness
Same question too for exhaust manifold.
The mental gymnastics a landlord will employ to justify immoral actions is clinically fascinating. Just because something is legal doesn't make it moral.
Mr Whippy
posted on 19/6/09 at 11:29 AM Reply With Quote
you can use a little smear of this on the inlet gasket (both faces), especially if its not a thick gasket
as for the exhaust, personally I'd not use anything as its usually sealed by metal edging being compressed and any paste tends to expand unpredictably and could restrict the gas flow. Use that kind of paste on exhaust joints only.
[Edited on 19/6/09 by Mr Whippy]
flak monkey
posted on 19/6/09 at 11:56 AM Reply With Quote
I never use any gasket jointing compound other than on sump gaskets.
If the faces of the manifold and head are flat then you shouldnt need anything more than a gasket.
Sera
http://www.motosera.com
Dingz
posted on 19/6/09 at 12:21 PM Reply With Quote
I usually just use a smear of grease, helps hold them in place too.
adithorp
posted on 19/6/09 at 12:28 PM Reply With Quote
I wouldn't, except just a smear (not enough to squeeze out) of hylomar around any waterways.
adrian
http://jpsc.org.uk/forum/
posted on 19/6/09 at 12:38 PM Reply With Quote
nope - you souldn't need to.
for sump gasket it sometimes helps to put a bit to help hkeep it in place.
I do use it for water pumps but not for oil, air or exhasuit gas.
In fact, overdoing it can be gadas the sealant gets sueezed out, break off and block oil/water waqys.
In the past I've picked out chunks of it from the radiator filler!!! (ot my doing).
Maradona
posted on 19/6/09 at 02:25 PM Reply With Quote
In the manyfolf and axaust personaly I prefer don t use anything
cheers
Diego,
The locost builder from Argentina
tomprescott
posted on 19/6/09 at 06:27 PM Reply With Quote
Ditto
Benzine
posted on 19/6/09 at 07:08 PM Reply With Quote
thanks for the replies ^_^
jpindy3
posted on 19/6/09 at 08:05 PM Reply With Quote
mate use gasket seller the blue stuff the best,
if you dont and you manifold ant flat like some are you will end up filling 2 3 cyl up with water.
trust its happend to me,also that means new oil
posted on 21/6/09 at 03:42 PM Reply With Quote
I have never known any manufacturer to use any sealant on a manifold gasket. If the manifold isn't flat you may have problems but you would be better off sorting out the distortion anyhow.
