Author: Subject: moving from MS2 to MSExtra 2
corpi
posted on 24/6/09 at 08:43 AM Reply With Quote
Hi another question:
Until now i have been running standard MS code V2.89 and have wired my MegaSquirt as per standard Scheme
I would like to try MSExtra v2.0.1 code. Can I just load the code, and make sure that the ingnition output points to JS10, instead of D14, in the settings via MegaTune,
and all the connections would work?
I realise I need to redo all the other settings too.
I'm running a standard coil powered by a BIP373 through pin 36 on the connector.
At this time I don't want to make any wiring changes!
I could not find anything by searching.
thanks for any help Pieter
